Guide: EVAL1 off/on trigger
MSL
Denmark
I would like to share my setup which is used for AirPlay, and nothing more than that.
My equipment is as follows:
Purifi EVAL1
smps1200a400
SMSL SU-8s
Raspberry PI4
Elac FS407
My goal was to achieve the greatest possible user-friendliness, while not compromising on quality.
The first thing I did was buy two of these: https://www.conrad.com/p/tru-compon...cal-number-of-pins-2-mono-black-1-pcs-1567107
One connected to the smps1200a400 (GPIO / GND to PIN J5.1 / J5.5) and the other to the Raspberry PI (GPIO / BCM pin 21 and GND39) then just connect the PI to the smps1200a400 via a minijack cable
Notice my 5A fastblow fuse, unbelievable he does not add it :(
My wish is that my PI should turn on my amplifier when music is playing, and turn it off when nothing is playing and after 5 minutes.
And here I must admit that I came across a difficult task. Because I can not code anything. And I could not find anything that lived up to what I want. Yes. Volumio has a plugin, it only works during play / pause and not when the music stops by itself.
So ... I had to get started :)
The following is code without explanation. The purpose is as written to get my amplifier to turn on when music is playing and turn off when no music is playing and after 5 min
Download, install Raspberry Lite https://www.raspberrypi.com/software/
Write an empty text file named "ssh" (no file extension) to the root of the directory of the card.
Create a text file called wpa_supplicant.conf, and place it in the root directory of the microSD card.
Code:
country=DK
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
scan_ssid=1
ssid=“your_ssid”
psk="your_wifi_password"
From Mac via terminal
ssh pi@ipadress
Password:raspberry
Change the password!!!
sudo raspi-config
Update Raspiberry
sudo apt-get update
sudo apt-get upgrade
sudo reboot
Install shairport
https://github.com/mikebrady/shairport-sync/blob/master/INSTALL.md
sudo apt install --no-install-recommends build-essential git xmltoman autoconf automake libtool libpopt-dev libconfig-dev libasound2-dev avahi-daemon libavahi-client-dev libssl-dev libsoxr-dev
git clone https://github.com/mikebrady/shairport-sync.git
cd shairport-sync
autoreconf -fi
./configure --sysconfdir=/etc --with-alsa --with-soxr --with-avahi --with-ssl=openssl --with-systemd
make
sudo make install
sudo systemctl enable shairport-sync
sudo systemctl start shairport-sync
Shairport settings
sudo nano /etc/shairport-sync.conf
Code:
general =
        name = "Eigentakt";
        volume_range_db = 80 ;
        volume_control_profile = "flat";
sessioncontrol =
        run_this_before_entering_active_state = “home/pi/pyh/stop.py";
        run_this_after_exiting_active_state = “home/pi/pyh/start.py";
        active_state_timeout = 300.0;
alsa =
        output_device = "hw:1";
On/off on play/pause/music stops via GPIO
sudo apt install python3-gpiozero
sudo usermod -aG gpio shairport-sync
sudo mkdir pyh
cd pyh
sudo nano start.py
Code:
#!/bin/python3
from gpiozero import LED
from signal import pause
led = LED(21)
led.on()
pause()
sudo nano stop.py
Code:
#!/bin/python3
led = LED(21)
led.off()
pause()
sudo chmod +x pyh/start.py
sudo chmod +x pyh/stop.py
Off on boot via GPIO
sudo mkdir logs
cd pyh
sudo nano launcher.sh
Code:
#!/bin/sh
# launcher.sh
# navigate to home directory, then to this directory, then execute python script, then back home
cd /
cd home/pi/pyh
sudo python3 start.py
cd /
sudo chmod 755 launcher.sh
sudo crontab -e
Code:
@reboot sh /home/pi/pyh/launcher.sh >/home/pi/logs/cronlog 2>&1
sudo reboot
Play and forget
M
MSL
Denmark
If you find that the music stops and starts, then you are probably using the built-in wifi (Do not) use a cable.
If you do not want it, or have no other options, try the following:
sudo nano /etc/network/if-up.d/off-power-manager
Code:
#!/bin/sh
/sbin/iwconfig wlan0 power off
sudo chmod +x /etc/network/if-up.d/off-power-manager
or
aplay -l
sudo nano /etc/asound.conf
Code:
pcm.!default {
    type plug
    slave.pcm {
        type dmix
        ipc_key 1024
        slave {
            pcm "hw:1"
            period_time 0
            period_size 1920
            buffer_size 19200
ctl.!default {
    type hw
    card 1
bigjacko
Thanks for documenting your way, although I can't follow much. Do you mean the built in wifi on pi is bad, and we should use ethernet cable or usb wifi module? I want to just use wifi as is, I would really hope the wifi on pi just works.:oops:
M
MSL
Denmark
No. But all the problems I have had have been related to bad wifi connection and I have good connection and on a 1000/1000. If you experience that the music stops and starts inappropriately, then I experience that it is bad wifi.
If you want to follow my example, just take one line at a time :)
Honken
Scania
Many use metal cases for their Pis, that can make getting good reception difficult with the built in Wi-Fi. Not sure why people see this as an absolute must, at least not for audio applications.
Built in Wi-Fi or not, power saving should be disabled for your Wi-Fi interface if you wish to stream to your computer over Wi-Fi.
M
MSL
Denmark
I can well understand you want to wrap it nicely. One just has to be aware that it has its drawbacks.
Regarding wifi, therefore:
Code:
#!/bin/sh
M
MSL
Denmark
The pi>smps>amp
The smps get 0V from the pi on play and 3.3V on stop/pause
M
MSL
Denmark
Hypex1200a400 have that functionality
Audio jack Socket connected to the smps1200a400 ( PIN J5.1/J5.5) and the other to the Raspberry PI (GPIO/BCM pin 21 and GND39)
abdo123
Brussels, Belgium
Oh cool thanks for sharing. I wish you did a thorough breakdown on these sort of details because that’s really what makes all of this possible.
M
MSL
Denmark
By the way, I can add if you need 3V, and not 0V to trigger your smps to turn on, then swap these start.py and stop.py so it looks like this:
Code:
run_this_before_entering_active_state = “home/pi/pyh/start.py";
run_this_after_exiting_active_state = “home/pi/pyh/stop.py";
M
MSL
Denmark
Update to stop.py and start.py
Code:
#!/bin/python3
led = LED(21)
led.off()
pause()
There is no need to spend resources on keeping a script running, so therefore:
Code:
#!/bin/python3
import sys
from gpiozero import OutputDevice
sys.path.append("/home/pi/pyh/start.py")
amp_on = OutputDevice(21)
amp_on.off()
quit()
And update start.py
Code:
#!/bin/python3
amp_off = OutputDevice(21)
amp_off.on()
pause()
Find the right pin: https://pinout.xyz/pinout/pin40_gpio21
