Halp!! I have the itch to upgrade.
_thelaughingman
The upgrade itch is back. I can’t decide what I want to upgrade or buy. I want to get a new turntable and or a set of headphones but can’t decide which is more needed. ‍:facepalm:
Want to upgrade my turntable from Audio Technica AT-LP60 to a Fluance RT-81( plan to put my an Ortofon Cart on it after). Can’t decide if I want to buy Hifiman HE400i or the Sennheiser HD560s.
Ah the dilemma of being an audiophile.
_thelaughingman
_thelaughingman
_thelaughingman
_thelaughingman
Helicopter
Michigan
What headphones do you have?
What Ortofon are you planning to get?
You might be better off getting a better stylus for the AT cart with the RT-81 or getting a turntable that comes with an Ortofon.
Sukie
Beer? Porn? New pet?
None of the above? Looks like a new turntable or phones:)
_thelaughingman
_thelaughingman
I have Sennheiser Hd555 and Grado SR80e. I plan to get the Ortofon Blue for the upgrade.
_thelaughingman
_thelaughingman
What do you listen to the most, you turntable or headphones? There in lies your answer.
I listen to them both equally which is the biggest conundrum.
_thelaughingman
_thelaughingman
_thelaughingman
_thelaughingman
I think I might invest more and get the RT83 since it comes with an Ortofon.
_thelaughingman
_thelaughingman
Helicopter
Michigan
83 comes with a Red, which is nothing special with a bonded elliptical. 85 is cheaper than an 83 and a Blue stylus and comparible to an 81 and a Blue cart. And you can afford the 85 now because I suggested the $9 headphones.
AdamG
Moderator
Reality
And get the $9 Sony headphones. :)
Brilliant suggestion. Keeb, have you seen Amir’s review on the $9 cans? Actually a very good suggestion if you have Eq capabilities.
We double posted so belay that!
