Handmade copy of Purifi SPK5 design on UK eBay
sgoldwin
London, UK
I built three pairs of SPK5 speakers close to the Purifi published SPK5 spec. I am selling two pairs and keeping one. If there is demand for this I will keep building them.
Pictures, description and price on https://www.ebay.co.uk/itm/303634158293
Thomas savage
The Watchman
uk, taunton
Matias
São Paulo, Brazil
Yes, testing would be a great way to promote it.
jhaider
Curious - why speakONs on the PCB for the individual drivers? While I do not think there is an equal or better option for amp-to-speaker wiring, it seems to me that simple quick disconnect tabs for PCB to drivers makes more sense.
sgoldwin
sgoldwin
London, UK
The obvious answer, on the speakers I'm making, is that's the way Purifi did it and I'm trying to build a technical copy. Purifi has identified speakONs as the lowest distortion connector but I do not know if they included simple fastON connectors in that analysis.
jhaider
Fair enough.
I doubt they did, and that's not possible anyway given that there fastON terminals inside the speakON connector. :)
My view is performance-wise it does not matter, as long as the boards fit into the cabinet. I was just curious because that's a multiple-times-more-expensive way to connect drive units to a PCB, with more points of failure than a faston or barrier strip.
D
Deleted member 15250
Guest
Great looking speakers, looks like you forgot to enable bidders from the usa
yourmando
I have a new listing on eBay for 6 copies of the SPK5 speaker, also available through my website celuaris.com.
And, I have submitted the speaker to amirm for testing.
Curious why have you left the crossover external? The SPK5 demo has it this way so that speaker designers/evaluators can swap in their own crossovers or tune parameters easily.
ironhorse128
What I do not understand is why there is only one speakon connection per speaker. The crossover is external, so there should be two connections going to each speaker. What am I missing?
yourmando
It uses a 4 pole Speakon connector.
Speakons come in 2-pole, 4-pole...even 8-pole. I have a single 8-pole Speakon going to my speakers from the active x/o and amp.
AudioJester
Very nice. Guess you could use a minidsp 2x4 and ditch the passive crossover and use a 4 channwl amp?
sq225917
Make the product image on the homepage a url link straight to the product in the shop
