Has anyone heard speakers with a wider soundstage than Revel's?
BingaMoon
Let's say under $3k. I've heard a good number of speakers but Revel's had the biggest soundstage and was curious if anyone has heard something that had a noticeably wider soundstage?
GXAlan
richard12511
Focal, Ascend, and Philharmonic should all be a little wider. BMR Philharmonic towers are hard to beat around that price if you love a wide soundstage.
richard12511
Is there a direct correlation between wide dispersion and wide soundstage?
From what I understand(there's a graph that Toole shows), the 2-10?kHz region dispersion width is most responsible for soundstage width. This may be why you tend to see a bulge in that region for Focal. Revel tends to be a little less wide, but smoother with respect to the surrounding regions.
aarons915
Chicago, IL
That's my understanding as well. The OP said wide soundstage so I mentioned the RAAL but vertical dispersion seems very important as well and I don't think you can neglect it.
MediumRare
Chicago
All the speakers with reasonably flat FR and smooth dispersion (whether narrow or wide) should have excellent soundstages. Look at the list of reviews. A lot of the good speakers are well under $2000 a pair.
Pdxwayne
My living room front wall is ~23 ft wide. My Paradigm speakers (Studio 10, Signature S2, and Persona B) all can cast stage wider than my front wall.
I would say any good Paradigm pair under $3K can provide excellent width.
jtgofish
Language warning! A four letter word is about to be used ........... Bose ....[901].
Kal Rubinson
Industry Insider
NYC
Hmm. In my experience with the Beolab 90, increasing dispersion (which can be manipulated) did increase the width of the soundstage but at the expense of detail, imaging and specificity. Perhaps there are optimal values, depending on room dimensions and boundaries.
P.S.: To answer the question in the thread title, I have not yet heard any speaker with a wider soundstage in my listening room.
Duke
Princeton, Texas
To the extent that the apparent soundstage width is expanded by early reflections off the near-side wall, probably so.
To the extent that lateral soundstage extension beyond the speakers is encoded into the recording, probably not.
While I have not heard the Beolab 90's, I can't think of a more apples-to-apples comparison of narrow vs wide vs omni radiation patterns, so I find your observations about the Beolab 90's quite valuable. Your experience regarding the tradeoffs of wide dispersion (relative to narrow) makes sense to me, being a disciple of Earl Geddes:
"The earlier and the greater in level the first room reflections are, the worse they are. This aspect of sound perception is controversial. Some believe that all reflections are good because they increase the listeners feeling of space – they increase the spaciousness of the sound. While it is certainly true that all reflections add to spaciousness, the very early ones (< 10 ms.) do so at the sake of imaging and coloration."
Doodski
That might explain why I've had success with using damping panels behind my head on the wall directly behind the sofa. :D Everything improved.
Duke
Princeton, Texas
aarons915
Chicago, IL
I've also seen a study that systematically added absorption panels to various 1st reflection points and basically supports your statement that the more reflections the more spaciousness that was reported but the dead room had more clarity. I too suspect there is an ideal dispersion pattern which is why I don't go for speakers where wide horizontal dispersion is prioritized over just about everything else. I also think vertical reflections are important to the overall soundstage as well.
Cadguy
The Elac Concentro M has some type of technology that allows for adjusting between "spacious" and "focused" sound. It will be interesting to find out how they accomplish this and it may add more data about how speakers produce in-room soundstage width.
dkinric
Virginia, USA
Just a personal data point as I see the RAAL tweeters mentioned vs Revel. I recently replaced my Sierra 2s with Revel M105s - direct replacement, same stands, same location - and soundstage appears to be noticeably wider with the Revels. Don't discount the engineering that goes into the waveguides of the speaker in addition to tweeter characteristics. Of course, YMMV.
