Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
I wonder if @amirm or @WolfX-700 will measure the A50?
Should work just fine.Hi, I'm looking for an amp for my Akg k712 pro, the A50 topping is a good choice for me ?
Any of them will probably do as well as new Schiits. IIRC Liquid Spark's distortion start to rise pretty quickly with output power increase.what is the best amp for akg k712 pro, topping A50, liquid spark or jds labs atom ?
Seems like the Topping is the worst sounding, least transparent, the "fun" amp.
It's funny you interpreted his words into something you want to believe...
I wanted to believe it's the bees knees, apparently it's not. You want to believe I said it's bad, I said it's the worst sounding of the set, meaning the other sound better, according to Zeos. can sound amazing, and still be the worst, if the other sound better ;-D.It's funny you interpreted his words into something you want to believe...
What he actually said:
Topping is the most enjoyable one. Least transparent out of the three but still transparent. Build quality is the best.
Where did you get the worst sounding?
indeed, and there are no measurements of the topping, so he doesn't know what to make out of it.z-reviews is good for build quality, UI interaction, how features work, and little else past that.
1, He didn't say it was the worst.I wanted to believe it's the bees knees, apparently it's not. You want to believe I said it's bad, I said it's the worst sounding of the set, meaning the other sound better, according to Zeos. can sound amazing, and still be the worst, if the other sound better ;-D.
This is why I'm still hoping for A50 measurementAnd, since this is audio science forum, what makes you think they sound different as they all measure well enough to be audibly transparent to, meaning no difference. All the better or worse are only measurements.
I have seen about 100 Zeos videos, he said it's the most fun, less transparent (=the least transparent, =the most sound altered); THE WORST
Not that I would believe much when Zeos talk sound details. Still great reviews, no bs, talks all the real functionality. THE WORST.
I will now explain what the worst mean in a comparison group; the others are better. It doesn't mean it's bad, he says it's awesome. It can easily be truly amazing amp, and still be THE WORST.
It's just a fancy power supply and should not make for an audible difference..What does the linear power supply do and how does it help in this context?
