Headphone amplifier new vs vintage?
DanielT
Sweden - Слава Україні
See from # 17.
What do you think?:)
solderdude
The Neitherlands
The NAD 3020 is not really suited as a headphone amp. Output resistance is a whopping 220Ω
Robin L
1 mile east of Sleater Kinney Rd
New. The headphone outs on old receivers are usually noisy. My Topping L30 is dead silent.
Robin L
Any other vintage brand, model? Or maybe they are quite similar in that respect, regardless of make / model?
I think a lot of the headphone outs are the amp signal through a resistor that drops level, raises impedance. So not a design for a headphone amp, just an afterthought for the features list.
And when I said the Topping L30 is "Dead silent" I was referring to background noise. Music is more than loud enough via the L30.
LTig
Europe
I think almost all integrated amps and preamps and probably also many vintage headphone amps have too high output impedance-certainly for todays low ohm headphones. At vintage times many highend headphones had impedances from 150 to 600 Ohm, but today they go down to 12 Ohm!
DanielT
DanielT
Do you mean, for example, the mechanical hum that CAN come from old vintage amp transformers? It is undeniably a matter of taste whether you accept it or not. Or do you mean noise that you hear in the headphones?
Hm, how do headphone jacks work in integrated amplifiers? What I mean is that the amplification of the signal hardly goes via the power section and then via various resistors is attenuated? The signal should go to the pre amp part, which is operated in class A (if I am not mistaken). So, eh hm. I really do not know. Basic amp design and I do not know. Sorry.
Edit:
I posted my post and now see threni and LTig's comments. :)
Robin L
Do you mean, for example, the mechanical hum that will CAN come from old vintage amp transformers? It is undeniably a matter of taste whether you accept it or not. Or do you mean noise that you hear in the headphones?
I mean noise I hear from the amp via headphones, hiss & hum, usually. To the best of my knowledge, a lot of the older designs take the amplification intended for the speakers and drop the level with resistors for the headphone out. The self-noise of older amps is a lot higher than on modern designs.
DanielT
DanielT
Interesting. Is it performance in itself that does not live up to the current sound ideal / expectations or is it the tooth of time that has deteriorated the sound quality? So the electronics in the amplifier have deteriorated, compared to what it was like new.
Edit:
Why take the signal headphone jack via the power amp part? It seems backwards.But maybe there are different design solutions?:)
Robin L
No, the difference is in the quality of the design and execution of modern headphone amps. Before desktop audio and the rise of audio headgear, "headphone amps" were not a thing, so manufacturers took the cheapest route for "headphone out" with receivers and amps.
Edit:
I dunno, ask an EE, I'm just a lowly recordist.
DanielT
DanielT
Hum, I'll try one thing. Via the headphone socket in the amplifier and via the mounted pre amp.
I'll be back. :)
Edit:
I'll just fix, see picture.:)
solderdude
The Neitherlands
Nearly all amps from that era and many poweramps with a headphone out even today use the poweramp outputs through resistors.
Works fine for high impedance headphones, which most were back in those days.
This was done because headphones in these days required a high voltage and this was already available at the speaker outputs.
DanielT
DanielT
Aha, interesting. I did not know that. What I do know, however, is that our ears are different, so you have to fix sensible sound with ::)
Edit:
Just want to add to the protocol that when it comes to sound and Hifi, I am not fixated on Vintage! Although I think the Vintage look is nice. :)
Good sound then it is probably most affordable with new, perhaps. Can I guess. Of course there is good and bad old as new Hifi, but in general. By the way, if Vintage can measure up to something new, see here (you probably know the thread, more general information to others):
Old vs nowadays I only say the digital world and HiFi. Then it was basically decided.:)
tvrgeek
North Carolinia
I remember when the Grado RA1 and Coy were the hot amps. Much has changed. For $100 to $150 you can get an amp that can drive anything and distortion below the threshold of hearing. So why not?
Solderdude, not quite so. My first cans were Sony, 8 Ohms. If I remember, many of the early Koss were below 32, as are my Grados.
But using the big power amp and resistors is far higher distortion and noise than can be had now for chicken feed. It was done because it was cheap, and back then, features counted. The more jacks and switches, meters, lights, and wood cabinets the better.
