Headphone Fundamentals
A
AudioStudies
I am curious what would be the next logical steps to enhance this document by adding a few more topics regarding headphones and/or headphone amplifiers. The document makes it clear that low output impedance in the amplifier is desirable, however I didn't discuss amplifier power nor do I know the best way to discuss it. Are there any other amplifier specs besides output impedance and power that are relevant? Also, I suppose I could take a stab at explaining headphone target curves.
solderdude
The Neitherlands
Frequency range, phase, input impedance, volume control, gain, noise, distortion (profile), connectivity (SE, balanced) to name but a few. Not to mention ergonomics, weight, operating principle.
solderdude
The Neitherlands
Yep, and things like fully balanced throughout or not and component choices.
solderdude
The Neitherlands
I use your list regularly for years and already wanted to ask you if an update might come. Several of the headphones that I use for testing are missing as they came out around or after 2016. This list is too good to not keep it alive!
Updated... thanks or reminding me.
3125b
Germany
There is a mistake however with HiFiMAN Susvara data set.
EDIT: Actually, the whole "power" section is off for all headphones.
solderdude
The Neitherlands
yep.. something is was fishy...
Power levels seem correct though
Do note that the 90 and 105dB SPL columns are in mW and the 120dB SPL is in Watt.
The voltage column (left of the dBmW) was incorrect (For some reason had a 1.5x multiplier in it)
3125b
Germany
Probably the Bass.
Alright, I stole that from the other guy ... :)
