Headphone Out on Casio Piano
Laserjock
Texas Coastal
Rolls MB15b Promatch 2-Way Stereo Converter https://a.co/d/9ka11q2
With appropriate cables. It’s stereo out so you need to convert to balanced stereo out RCA to Balanced XLR/1/4” TRS input
Edit: the Rolls has 3.5mm in also
DVDdoug
This should work...
A headphone signal is about "line level" except it's capable of driving lower impedance headphones and the headphone output almost always has a volume control where sometimes a line-output does not.
If the output is stereo you need to "split" the left & right into inputs 1 & 2. You'll probably need a combination of cable adapters...
"Mono" TS Adapters (like a guitar plug) might be "safer than a TRS plug because a TRS plug might make a balanced connection* (the headphone output is unbalanced) and it's just easier to get the correct connections. Then you'd need a cable like this.
This probably isn't necessary but for "deep troubleshooting" you might try a headphone Y-splitter so you can plug in headphones at the same time to see if somehow connecting the interface is killing the signal.
*Stereo into a balanced connection results in left minus right subtraction and that would foul-up the signal in "strange ways". With regular stereo music it makes a "center channel vocal" remover, which removes everything in the center (everything identical in both channels) including the bass. If the output is actually dual-mono.... Both channels identical but with a stereo plug so you get sound in both ears... Of course subtraction gives you silence (or near silence).
H
Hewbacca
I don't suppose any of you know if other, better, digital pianos put out mono signals and would use just one input on my interface? Or is this just a common thing for pianos specifically as opposed to other types of instruments?
antcollinet
UK/Cheshire
I'm assuming your piano doesn't put out different left/right signals. (why would it?)
If that is correct, then you can simply use the splitter cable mentioned above, and only connect one of the L/R channels.
H
Hewbacca
Brilliant. I will try this and report back.
tomtoo
Germany
No, keybords give usually stereo signal. For reverb, and other stereo effects.
So you need both channels of your interface.
H
Hewbacca
Thanks. I am talking to a streamer friend of mine as well, I think most pianos do audio over USB and that is how most people are getting the audio out of them. The ones using analog are typically using splitters.
tomtoo
Germany
So you just use the splitter and connect to both inputs to the scarlett.
H
Hewbacca
Confirming, splitter cable with both ends connected to interface sounds identical to headphones connected directly.
The theory that one end of the splitter cable connected to one interface, and interface set to mono would sound the same, disproved. It sounds better than the original setup, but still losing information vs. using both ends & two interface ports.
Thanks all for the help!
