The Sony HF755 which you probably could find for 5$ come very close to Harman target. Harman target ain't my thing. To much bass bost which smears low midrange and male vocals. Initially it does sound more plesent thanks to warmer signature but that's just deception. Then again that something is close to the Harman curve absolutely doesn't mean it will sound good.
You already played with Wavelet which is probably the easiest way to find it out for yourself.
Is there a graphic somewhere on which the different target curves are compared? I would like to compare Harman Target and Diffusfield etc. to get a feeling for how they differ.
Me neither, so I entered them by hand. 9 filters with freq/gain/Q is not too bad
I can zip and attach my preset file if you're interested in the Fidelio X2's correction curve.
I'd be very much interested if you could share it. Thanks!I can zip and attach my preset file if you're interested in the Fidelio X2's correction curve.
Here you go. One with and one without crossfeed enabled.I'd be very much interested if you could share it. Thanks!
@brachypelma44
Hearsay and other information far less interesting than factual measurements: The theory is they relaunched the X2 as X2HR with minor improvements in the headband and earpads. Going further into assumption land, some think it was done to get rid of the bad reputation the X2's that were produced by Gibson got. The original X2 was produced by both WOOX and Gibson, so your results could vary depending on which you received. The X2HR are no longer produced by Gibson.
So, probably they are very similar, although different earpads can influence the sound...
With 5 PEQ available and a set of Shelf filters (LF+HF) on the THX788 you might be better of using these Philips Fidelio X2HR (RME ADI-2).pdf (dropbox.com) settings where filters 7 and 8 are the shelves and 1 through 5 for the 5 PEQ slots.
Strange, the manual on page 13 made the impression the LF and HF shelves can be set between 60-200Hz and 5-12kHz respectively.there doesn't seem to be a way to set the shelf filters to a specific frequency
You are not misunderstood. But the Oratory PDF I shared uses shelves in combination with PEQ (peak) filters to reach the desired correction curve.
You're especially missing quite a significant bass boost below 105Hz of 5.5dB.
So to match their instruction set the LF shelf like band 7 and the HF shelf like band 8. Alternatively use HF shelf for the far bigger correction of band 5 and ignore band 8.
7 (LF shelf) becomes your 'bass knob' and 5 (HF shelf) your 'treble knob' you can set to taste. To me the bass boost sounds a bit excessive; the Fidelio X2 is already bass-strong.
