Hedd ‘MainTowers’ arrive !
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Well they are in different rooms at the moment.
Soniclife
There you go, completely flat no EQ, just some Modex panels in the room, the room isn’t perfect and I have to use the Illusonic with the horns which are still at the other end of the room.
Is that a 30db bass lift at the bottom end? Hard to read with that scale. I'm sure it's the room not the speakers though.
Snarfie
Netherlands
Despite they are in different rooms something like an overall difference in imaging must be probably be noticed. Because of already the enormous height of the HEDD's in comparison with the D&D's there most be something like an vertical image difference i guess.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
About 20-24dB if I remember correctly, around 30Hz, It was that problem that led me to ... Trinnov, Dirac, Room perfect, Illusonic ,Modex tuned membrane etc etc, the other room is much more benign.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The ‘Towers’ don’t produce a disproportionate image size, the midrange module tweeter etc is at/around ear height, the subs cross at 80Hz I believe.
Snarfie
Netherlands
Philips had in the 70ties a experimental sound systems consisting of speakers that where strategically placed thrue the room vertical from the floor to the ceiling. Don't know the name of this experimental system it was also never been in production because of the sheer size an eventualy was difficult to sell. A Freind of mine who was invited heard the system an was quite impressed.
Krunok
Zg, Cro
Can you please rescale this graph to show y axis range from 30 to 100dB instead of -100 to 200 and x axis range from 20Hz to 20kHz?
What kind of smoothing did you apply?
Soniclife
I would expect them to be no different to a pair of stand mounts, with 2 subs on the floor, and another 2 subs bolted to the ceiling.
Krunok
Zg, Cro
It is hard to tell from the graph but they seem to be a little heavy on the bass - diff between 30Hz and 1kHz seems to be app 20dB.
Krunok
Zg, Cro
Do you mean 100hz?
No, I mean 1kHz.
Krunok
Zg, Cro
I see what you mean now, I read it wrong.
The lift looks like room gain and room problems not speakers, so it should be very fixable. As it is there will be a lot of grunt, but it's wrong.
Yes, it's probably the room. From 100Hz above they look ok, although it is hard to judge how linear they are as graph scale is too large.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
The room is totally in control of the low bass of any speaker , and that is not an easy room, I will post another set of measurements when the horns have left and I can optimally position the towers.
Krunok
Zg, Cro
I agree. Looking at LF response without room EQ doesn't make much sense, but I would really appreciate if you can re-post this graph with the scale adjusted as I suggested in my previous post.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Gloss black pair of these ordered,
Hedd Audio’s ‘Tower Mains’, main studio monitors.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
After a short hiatus Hedd’s ‘Towers Main’ arrive here early next week, they are active , ( 26 drivers in total) but don’t have on board DACs/ad so I am going to use the Mola-Mola ‘Tambaqui ‘ which is ROON ready.
So the entire system will be Roon ‘Nucleus’, Tambaqui and Hedd’s Mains.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Arrived, heavy, four times TMS 36 subs 2 times TM80 mains.
