HEDD Type 05 Mk2 vs Genelec 8030
Music1969
This is excellent (compared with Genelec 8030)
Korean website via Google Translate
voodooless
Netherlands
Sadly no off-axis measurements. It also has significant resonances if you leave the port open.
YSC
I wonders why the port closed have even better low frequency extension
voodooless
Netherlands
Because there is more going on than just closing the port:
JSmith
Algol Perseus
There are no details in the review about the measurement system used... and it 'aint a Klippel setup that's for sure. ;)
JSmith
YSC
Ah, I see then, but then I wonder again... if the port is blocked and have a corresponding setting to make it flatter, why they still creat that port... for a few dB of headroom?
voodooless
Netherlands
YSC
Probably. It can be quite significant. Distortion wise as well.
But it’s also a marketing instrument. They call it CoP (Closed or Ported):
Just wonders if set the bass extension to 38hz and plug port what will the measurements be like.
