Help: ARC measurements of my room
sfdoddsy
Your response isn't as bad as it looks. The red line is the measured response, the green is after ARC correction.
The dips, as suggested, are room modes.
I would lower the maximum correction to 600Hz, which will increase the resolution of the corrections.
It's purely personal, but I'd lower the room gain a bit as well.
If all this is too techie, just switch ARC to Auto and let it do its thing.
You don't need to tweak to get a great result.
V
veeceem
Yeah too techie :) I should just set correction to 600hz max and leave the calculation to ARC :) thanks
V
veeceem
My lastest measurement of ARC after remove some acoustic panel.
Can someone take a look and tell me if this is considered better or worse?
Thanks
  • NOBACK_ARCNEWEST.pdf
V
veeceem
