Davide
I think you're missing some basic understanding of how digital audio works."Mixer' faders change the level obviously (it's a mixer!).“
Yes obviously
„Yes"
So also obviously Toslink is not fixed level or else the Flex would non „know“ when to get quiter. So there must be a Volume information transmitted
via Toslink or am i getting this wrong? I am starting to get very confused here
So i need a way to control the Main ou 1+2 in the CueMix via a Midi controller. Only dont know if the software supports this. Going to go out for a walk now….
But don't worry, I'm the one who's taking these things for granted...
Audio, whether digital or analog, is never at a fixed level... music is a continuous change in level, right?
So the audio waveform can go from a minimum to a maximum.
In digital terms this is 0 to 1, and the intermediate levels (0 point something) depend on the bit depth of the signal (16 bits are 2^16 steps, etc).
The toslink works digitally, therefore the signal is modulated in amplitude (or level) as just mentioned.
Changing the digital level of the music with the fader of the Mk5 mixer means acting on the volume of the audio which then passes through the toslink.
But it is not intended as a volume control of this output. The toslink output passes the audio digitally and that's it, there is no specific volume control.
I don't know if I can explain myself...
