- Joined
- Jan 27, 2019
- Messages
- 7,353
- Likes
- 12,330
- Thread Starter
- #181
After reading through this thread it reminded me of a similar problem i had a while back. Had a Benz cart on a Project 6.1 table. Started hearing distortion etc.. drove me nuts trying to chase it down. Ended up being a bad bearing/cup in the tonearm and it was slightly cocking the entire pivot making the azimuth badly misaligned. This ended up causing the suspension in the Benz to fail too.. so a combo.
I scored some new bearings from pro-Ject and recently resurrected the table with a used AirTight PC-1 a friend loaned me. Sounds great.
My opinion and experience: You really REALLY have to get your overhang/zenith, Azimuth & VTA dialed to get a consistently clean wonderful sound. I have used the Mint protractor on a few tables and it is very good.
I’d double check that tonearm and/or it’s bearing since the cleaning lady aced it. I have a hunch it could be related/causing some issue.
Keep us updated!
Thanks for the input!
I think I forgot to get back to this thread to report that once I had the new cartridge the distortion problem was gone.
BUT...it seems to have occasionally reared it's head again over the past several months. It's like the sound on one side will start to distort in to a ripping sound.
Usually just lifting up the needle and placing it down again seems to get rid of it. Mysterious. But thus far it's rare. (I guess I'm about two years in to using this "new" cartridge).
