I'm looking for a DAC to pair with Topping PA5 amp, max to 700 EUR.
Raspberry 4B is used as a streamer to DAC and then to PA5 amp.
I'm using Moode with PEQ, so MiniDSP flex/dac isnt required.
I have three "candidates" for DAC:
Topping EX5
SMSL DO200
Soncoz SGD1
I've had Topping E50 DAC, but it had a high pitch noise coming from unit (audible from cca 10-20cm away). So, the only criteria for DAC is NOT to have high pitched noise from the unit (or power supply).
Which of three mentioned DACswould you recommend?
Thank you.
Topping EX5
SMSL DO200
Soncoz SGD1
Thank you.
