Help me determine 2.1 speaker placement in a new small room intended for single person use
MeZoX
I have a very small room in the roof of my new house , its rectangular shape 1.78m x 2.2m
I have 2xKRK G4 8" and KRK 10'' subwoofer
I want to place a 55" OLED screen between the speakers on the 1.78m side of the room , the speakers would be a bit further up from the screen and a bit angled in toward the monitor , it wont affect screen visibility as there would be a recliner right in the middle of the room and this room is intended just for single person use
would it sound terrible because of the small room ? i am open to any suggestions to better utilize this room
MeZoX
MeZoX
need help with suggestions please , I am in the process of furnishing the house so i can still make modifications to the room before painting and electrical fittings are done
dshreter
You can definitely make it sound decent. I would consider acoustic treatment - a plush rug and ideally something on the back wall and maybe even side walls too.
AnalogSteph
.de
This is going to be a real tight fit. A 55" 16:9 TV is at least 1.21 m wide, and each RP8G4 is 0.266 m wide, not accounting for toe-in or the acoustic treatment on the side walls. Wall-mounting the speakers above or below the screen is definitely going to be your best bet. Side walls are going to require heavy acoustic treatment, and the windows should get thick curtains. I would place my seating position right between windows 1 and 2.
It's still the better option vs. the long side to the left, which would place you directly opposite from the windows. I don't think that would be very easy to get under control.
MeZoX
MeZoX
yeah sadly thats the only little space i can get to be fully mine lol
i was thinking the same thing about how a tight fit it would be ,i am thinking about mounting it above the TV m its a little challenging to find bookshelf wall mounts that allow for an incline toward the floor since the krk G4's don't have a mounting screw
what kind of acoustic treatment would you suggest for the side walls , and to which areas specifically ?
dshreter
Something like the rockwool panels from GIK.
Andretti60
San Francisco Bay
Are you sure about your measurements?
According to them the room is almost square (width to length ratio is 0.8) but from the picture you posted it looks much more narrow than that.
As other suggested, you’ll need some acoustic treatment starting with a rag on the floor and heavy curtains in front of the windows (that you’ll need anyway to watch the tv). Consider also wallpaper instead of just wall paint (it helped a lot in my small bedroom when I was a teen living with my parents)
MeZoX
MeZoX
yeah its just the wide angle lens that's causing the the side walls to appear more stretched I think
