Help with system: Dual Subwoofers, DSP Options, and General Audio Advice
vitty0425
Hi All,
Intro
I've been a long time lurker and always check for measurements / reviews on this site & others prior to purchasing any home audio gear. Really appreciate all the work and information this forum provides as it can provide a "reality check" for those emotional / impulsive purchases :). Quick intro: I got hooked into audio starting in car audio. Still have a fun system in my current car. Now I spend a lot of time on my desktop in a small spare bedroom working & listening to music so I've been slowly beefing up my desktop setup. Finally decided to create an account as I am looking for some recommendations for my desktop setup.
The Room: 11x9x9ft. Room doesn't have any acoustic panels / bass traps / diffusers. This is a spare bedroom so it has a bed, some furniture, boxes, a bookshelf, etc.
Current desktop setup: RME ADI-2 DAC FS --> Audiolab 6000A integrated amp --> Ascend Acoustics Sierra 2-EX (on 32" stands to meet ear level)
I only use digital sources like Qobuz, Tidal, Spotify, Youtube. I really like the RME because I use it as a headphone amp & switch between headphones & line out with a simple press.
The Sierra 2-EX speakers claim to typically extend down to 33hz in-room? Since there is a bed behind me, I can only place them 5" inches from the wall. Still, I really enjoy them as a near-field speaker. I recently ordered two SVS 3000 Micro subwoofers for additional low end thump. So I started looking into how I can best integrate two subwoofers. First off, I know the importance of measurements & EQing as my car was tediously tuned (lots of hours tuning and late nights by a good friend). I also purchased a UMIK-1 (on the way) so I can learn to do my own measurements. Initial plan is to get by using the PEQ settings in the SVS app to flatten as much as possible.
In the event the SVS app w/ the 3 PEQ is not enough, I was looking at the MiniDSP 2x4HD. Here are the questions based on the scenarios of adding it into the chain:
  • 1: Based on all the diagrams I've seen on the 2x4HD, it goes before the RME and directly to the sources. Instead, can I connect it after the RME? Meaning: Source --> RME DAC --> 6000A Integrated amp --> Amp's Pre-Out --> 2x4HD -- > Subwoofers. Probably not a good idea since I'll lose ability to high pass filter to my mains? Also may cause some time alignment issues? Ideally I want to use my RME as the main volume control since I can see the volume display and it sits on top of my desktop. Any workaround solution would be appreciated.
  • 2: If I do add the 2x4HD into the chain and if it had to connect directly to my sources (computer) / streamer before the RME, I have to use it as the main volume control to control both subs & mains?
  • 3: Something else? I was also looking at the SHD but that's a totally different beast. Also was going to get an NAD M10 for simplicity & use its room correction but I've been reading about the V1 issue with low subwoofer output levels?
Cheers!
alex-z
33Hz in-room is definitely a stretch. From their own measurement graphs you can see the bass rolloff starting at 50Hz.
To be honest, the SB-3000 Micro subs are super overpriced unless you cannot spare a single cubic inch of space in your room. A pair of SB-1000 Pro will perform substantially better for less money.
The miniDSP 2x4HD is an analogue to digital to analogue converter, and does all filtering in the digital domain. Using the RME ADI-2 at all would be redundant, you may as well use the miniDSP as your DAC and avoid an extra conversion.
What I would suggest is using the 4x10HD. Then you can have 2 outputs for the subs, 2 for your speakers, and 2 for your headphone amplifier of choice.
The alternative is to perform all your EQ via software such as EqualizerAPO. Only downside is then you are tied to using your PC as a source.
Ron Texas
Very small room. I wonder how to get low frequencies in there.
V
vitty0425
The miniDSP 2x4HD acts an analogue to digital to analogue converter, and does all filtering in the digital domain. Using the RME ADI-2 at all would be redundant, you may as well use the miniDSP as your DAC and avoid an extra conversion.
Yeah the micros are pricey but I wanted to try them out first in this small room with the space I have left. I was even considering placing one micro on top of the cabinet if needed. I was in between the SB1000 Pros as well. With SVS, I have time during the in-home trial so stepping up to another size is an option.
Good suggestion on the 4x10HD. I still prefer a physical volume knob, volume display, and the conveniences the RME provides. Another reason is because the RME is also my headphone amp. So I assume placing the 2x4HD or the 4x10HD after the integrated amp is not a good idea? In the case the RME is redundant, I may consider selling it and just get the MiniDSP SHD. Then get a separate headphone amp.
I do use EqualizerAPO to EQ my headphones now but I switch between my Mac & PC so EqualizerAPO isn't the ideal solution for both.
alex-z
If you are just sitting stationary at a desk, a single SB-1000 Pro will match a pair of SB-3000 Micro for output, and the worse room mode problems can just be EQ'ed away.
Placing your miniDSP after the amplifier doesn't work, because then you cannot apply any filters to the speakers, only the subwoofers. Which rather defeats the goal being able to high-pass the speakers for proper integration just like an AV receiver does.
Yes, I would sell the RME and get an external headphone amp. Something like the Topping L50 gives you top of the line performance for $230. I would just use the miniDSP 4x10HD, I don't see the SHD as being terribly practical because it only has 4 outputs, and 6 would be ideal for your situation.
DanielT
Sweden - Слава Україні
Hi All,
Intro
working & listening to music ..
How much space do you have in the room? How big subwoofers can you place in your room? If you take into account the size of the room and your furniture, that is.
If you work at the same time as you listen to music from powerful subwoffers, it will not be difficult to concentrate on the work then?
I did something similar in my combined work - listening room a few years ago but it ended up with me removing the large subwoofers. Mostly because they eventually took up too much space but also because I prioritized Hifi in the living room. But people are different. Different needs and priorities. Hope you get it working so you will be happy! Good luck.:)
V
vitty0425
Yeah, I didn't want to get anything too intrusive. I tried putting my SB-2000 in this room some time back and it did feel out of place. I like to have background music while I work and although I do get distracted finding new tracks to listen to, I think life is too short to work in silence :)
I'm going to try to work with one 3000 Micro first. I looked around the room and the Micro can fit in way more spots in the room compared to anything bigger. We'll find out this weekend!
phoenixdogfan
Nashville
Your chief problem IMHO is the RME ADI is basically a two channel stereo device whether your using it for a preamp for speaker or as a headphone amp, and it does not have an electronic crossover, and you need one. If your're sources are exclusively digital, you could add a second multichannel DAC preamp such as a miniDSP Flex and employ a usb switcher to change between depending on whether you are listening to headphones or speakers. The minDSP would give your the crossover, PEQ, routing, and channel timimg adjustment.
That crossover can also reside on your PC along with any PEQ through any number of pieces of software such a Dephonica, JRiver, Roon, Ekio, EAPO, or Rephase to name but a few windows based solutions. PC based software crossovers will not provide the additional two channels of DAC required to run the crossover in the digital domain, so you would need a four channel DAC in any case for any digital crossover.
Alternatively, some subs provide an analog crossover within which occurs after the two channel DAC conversion. You simply route what comes out of the preamp (in this case the RME ADI) to the subs input, select the crossover frequency, and the sub will route the high passed signal for the mains to the amp (in some models) while keeping and ampliflying the low passed within itself. Unfortunately SVS, I believe stopped offering the high pass portion on its subs which means the mains will just roll off ( in your case the Sierra 2-EX would begin roll off around 33-50 hz). Ultimately that could be the cheapest, but probably the least best, because the crossover between the subs and mains will not be right without a high pass filter.
Obviously, the hardware solution employing a miniDSP would be the all in one fix. The Flex could just be the the regular 4 channel version and it has a high quality DAC, a complete interface, and the capability of adding the world class Dirac room and speaker correction DSP for an additional $200. The USB switcher runs around $20. And yes, Flex has a big volume knob, with a prominent volume display. Very small package as well.
maverickronin
Midwest, USA
Just bite the bullet and put something like the 2x4HD after your RME to do the crossover even though the measurements won't be as pretty. That's what I did. It has too many unique features to get rid of.
djtetei
România
@vitty0425 Welcome to the community!
I have one suggestion for you: try to keep your setup as simple as possible, with short signal path and avoid multiple conversions from digital to analog and vice versa.
Your Audiolab 6000A is an integrated amplifier with built-in digital to analog converter and two pre-outputs. You can connect your digital sources directly to the Audiolab 6000A, use its pre-outputs to send the signal to your SVS subwoofers inputs and adjust the subwoofers built-in crossover to the required low pass frequency (between 60-80 Hz) to ensure good blend between the mains and subwoofers. Start at 80 Hz and, if possible or necessary, go down, in small steps, toward 60 Hz.
Don't try to set your crossover higher than 80 Hz. You want to preserve as much as possible of the main speakers sound signature and use the subwoofers to fill the low end, without over doing it.
If you want more control over the low end, you can use an active crossover in front of the amplifier.
