- Joined
- Oct 25, 2019
- Messages
- 11,122
- Likes
- 14,793
The biggest issue with soundstage is that it not only is pinna dependent but above all brain dependent.
For instance. I can't hear the sounds in front of me. Not even using binaural recordings. With spatializers I can hear a very unnatural effect.
However, with some of the better headphones I can much easier 'pinpoint', quite sharply, in position in the stereo width 'line' inside my head, I can easily separate instruments when tonal balance is flat.
With angled drivers this increases. It never goes 'forward' or out of the head for ME though.
In some very rare recordings where recordings are made with, as an effect, someone calling from afar I do perceive it as if someone does this from the room that appears not to be in the recording (but is)
I call this 'imaging' instead of sound stage or with headphones 'head stage'.
Other can hear sound in front of them. How would one capture this is numbers ?
Stranger still with good (in my case stats) I can perceive depth and width easily, even height for some obscure reason. So it is not that I can't hear it. Just not with headphones. Also my ears look rather 'average' so it is unlikely my pinna differs very much from many others.
For this reason I never looked into this aspect as I cannot hear and thus verify this effect... a brain thingy.
I have definitely perceived height with headphones, as well "out of head" width and depth. The HD800 (before EQ) did just that. After EQ- not so much but a better listen overall with EQ. But the ability to build that 3D space around my head was unparalleled. The Focal Clear have an element of that too.
