radix
- Joined
- Aug 1, 2021
- Messages
- 1,419
- Likes
- 1,364
Hi all,
What's the point of using high-rate DSD if one uses DSP systems that are going to sample at a much lower bit rate? For example, Genelec 8351B seems to use up to 192kHz sample rate (but at variable word size?). A miniDsp 4x10 HD active crossovers are 24-bit @ 96 kHz.
So, if one is using a DSP active crossover, for example, does anything beyond DSD64 or maybe DSD128 make a difference? Also, these systems support AES3 or SPIDF, which I think are 20 bits @ 48 kHz, maybe 24-bit @ 48 kHz?
To make this a bit more concrete, how does a DSD512 over USB to a Topping 90SE make an improvement over a lower-rate source, if one is going to feed it through a DSP system? Why not stick with AES3/SPIDF rates?
Personally, I'd assume (wildly guess) that having the active room correction from a DSP would give a much bigger benefit than high-rate DSD.
If there are already posts that go over this, please help me find them. Or if you know of a good article or technical reference, that would be great.
Thanks,
Marc
Thanks,
Marc
