High-res audio comparison: Linn Records Free High Res Samples
Guermantes
Brisbane, Australia
I thought oversampling in DSP was in order to avoid aliasing artefacts.
Here's a practical demonstration from FabFilter, makers of VST audio plugins:
redshift
Upsampling is converting a digital signal to a higher sampling rate, yes?
This adds no new information and no increase in resolution.
A digital signal could also have its bit-depth changed, say from 16 to 24 bits.
That process could push the noise floor down.
Truncation occurs in the LSB, which leads to quantization distortion.
At what dBFS do you think truncation of the LSB manifests?
It depends on how much processing you do, for example how many filter stages/types you got in the signal processing/feedback control pipeline.
redshift
Actually, I'll modify my reply, as I wasn't really addressing the question properly earlier.
If you are going back to the master tape (and just exactly what constitutes a master tape is a whole other conversation) there is a very specific reason to capture at a very high sample rate. You need to be able to capture the bias signal. This is going to be of the order of 150 kHz odd, and depends on the machine and sometimes even choice of tape. The reason for capturing the bias is to allow you to correct for speed variations, and critically, scrape flutter. When the tape passes the heads it scrapes, and just like a finger rubbing the rim of a wineglass you can get very fast changing modulation of the speed of the tape past the head. This leads to a form of intermodulation distortion that is welded into the tape at the moment of recording. If you can see the bias signal you have what amounts to a local clock embedded in the tape that you can use to deconvolve the flutter. If you have the luxury of finding the original tracking tapes you can recover real audio that nobody has ever heard since the day the track was laid down. Even if you only have access to the master tapes, you still have a chance to remove the last generation of scrape flutter.
So this is another issue with these high res releases from old tapes. It would appear that most have not taken advantage of this possibility, and thus have actually lost a real opportunity to crete a better quality release, and have simply been lazy and depended upon woo to justify what they are doing. Proper forensic analysis of the tapes and modern processing would have yielded a conventional 16/48 result that exceeds the real musical information available in the silly lazy money grubbing stuff they are actually pedalling.
Let’s not confuse the technical advantages of hires formats with marketing gimmicks.
If you sport a DSP in your audio chain it is almost certainly internally operating with 192kHz and 24/32 bits.
That is for a reason. Truncation is bad.
redshift
Nope, oversampling is for improving resolution. Say going from 8bits @ 10kHz to 12 bits @ 100Hz.
After all, many delta sigma DAC’s is 1bits @ X MHz
dc655321
Um no, DSP can be done entirely in software and at whatever frequency and bitdepth is appropriate for the application.
Just. Stop.
In your case, yes, improving the resolution potential of the DAC.
Note, this does not improve the resolution of the signal being converted by the DAC.
That was fixed by the original A2D conversion.
redshift
Just. Stop.
Haha, yeah a DSP is in most cases a programmable device. It’s up to you programming it to do basically what you want with the bits and bytes. Well, up to its rated performance and capacity.
Well of course you can recover more signal than what’s in the original low-res data but then you must know something about the source.
:D
Blumlein 88
:D
Care to give an example of this magic where you recover more signal than is in the original data?
redshift
6f6e65206b696c6f686572747a2073696e652077617665
Tell me what resolution and bitrate you want that data in.
dc655321
@redshift, I was giving you the benefit of the doubt, but am now convinced you haven't got a clue.
Bye.
Nehero
Can anyone confirm to me or not, as I am just starting to play with this program.
Are all those peaks that are visible on , simply distortions that we don't want?
R A I N (Demo)​
by Himmelsrandt
2. Drops
Spkrdctr
Bye.
The problem in this discussion is not once have you used the trump card word, Quantum. Therefore you have come to the end of a meaningful discussion. Throw it out there and see if it doesn't help. If it doesn't, go for some "String Theory" and if you need to drop a big bomb in the discussion throw out the words "Turbo Encapsulator" for the win!
Just offering free advice as it seemed you were getting frustrated.
julian_hughes
That's actually the initial scan results from a Tricorder used by Spock on a Class M planet. Weather: mild. Scenery: oddly artificial. Natives: restless. Sounds: pings, whooshes, that kind of thing.
danadam
No, more likely the harmonics of the violin (or is it viola?). And because this is not a hi-res file, most of those harmonics are quite important.
But that isolated burst in the spectrogram looks a bit suspicious. But then again I don't really know what exactly the program is showing there and SoX spectrogram doesn't show it:
