High Sensitivity Speakers
sweetchaos
The Curator
BC, Canada
I chose 87dB sensitivity as the thresh-hold, just to narrow down a lot of options...
Using MZKM spreadsheet:
https://sites.google.com/view/speaker-headphone-data/speakers/speaker-selector
Rating of 3 = Amir recommended = relaxed/lounging panther
Rating of 4 = Amir's highly recommended = golfing/soccer panther
Hope that helps.
Also, you didn't specify any budget?
Wombat
Australia
dB per metre or 4 feet? :)
Wombat
Australia
I get the impression that audiophiles don't like high-efficiency speakers. Are they too accustomed to the lower efficiency ones?
S
S. Ghosh
Kolkata, INDIA
High sensitivity speakers play well through low wattage amplifiers . And the low wattage amplifier costs much lesser .
Sancus
sweetchaos
The Curator
BC, Canada
WANT TO KNOW THE TRUE SOUND QUALITY ABOUT OMEGA & KLIPSCH
SPEAKERS WHICH ARE OF HIGH SENSITIVITY .
Don't know much about Omega, but I would avoid Klipsch.
Amir's review of R-41M:
https://www.audiosciencereview.com/...m-bookshelf-speaker-review.11566/#post-332027
No chance to fix with EQ, avoid.
Amir's review of RP-600M:
https://www.audiosciencereview.com/...sch-rp-600m-speaker-review.12138/#post-354117
These are salvageable with EQ....but I wouldn't buy anyway.
Also, read this post to understand sensitivity advertised vs measured:
https://www.audiosciencereview.com/...ker-sensitivity-advertised-vs-measured.14072/
@Sancus beat me to it ;)
Sancus
sergeauckland
Suffolk UK
That may well be the case, but I think that the compromises that have to be made to get high sensitivity also result in worse performance.
1) High sensitivity requires lightweight cones which are more difficult to make rigid, so have a worse breakup behaviour resulting in coloration. This can be mitigated somewhat by using exotic i.e. expensive materials, and/or stronger magnets, which in themselves cause other issues.
2) Horn loading is another way of achieving high sensitivity, but unless the horn is very large, bass will be limited, and any folding results in coloration.
3) Crossovers tend to be simple, as complex crossovers don't help sensitivity, and consequently slopes are low and out of band attenuation less than ideal, especially when using a lightweight paper cone as in 1) above.
4) Removing the need for high sensitivity allows more scope in design, given that high power is cheap and clean, although the problem of heat, compression and longevity/reliability becomes more serious when a loudspeaker is required to take more power.
With active 'speakers and Class D amplification, there's little incentive for high sensitivity, so more emphasis can be placed on accuracy.
S
S
S. Ghosh
Kolkata, INDIA
S
But class d amplifier is neither as good as class AB nor class A .
And high wattage class AB costs much higher which in case of class A , increases manifold.
