- Joined
- Jan 23, 2020
- Messages
- 4,338
- Likes
- 6,710
Just bought a new Windows Laptop I had planned to use as a HTPC and Roon Core, but just like the 3 other machines I've tried, the sound quality is terrible. Switching back and forth between the Roon Server playing on WASAPI output via USBc to HDMI converter cable into my Yamaha Aventage RX-A880 AVR and the Bluesound Node2I output via optical to the AVR makes the difference in sound quality quite obvious.. I've read Amir's thread about HDMI audio, so I knew going in that it wouldn't be optimal, but I guess I didn't think it would degrade the sound as much as it seems to be doing. I tend to think all electronics sound mostly the same, but that's obviously not the case here. I had thought that perhaps it was a MacOS thing, as the previous machines I've tried to use were Macbook Pros, but now that I'm experiencing the same bad sound with 2 windows machines(tried my Surface Pro as well), I know that it's not that.
Before anyone asks, no, the comparisons were not done blind, but there was no need, as the difference is quite large. Switching back and forth between the Blusound and the HTPC makes my 8351b speakers sound like my Google Nest Speaker. Seems to be more distortion and a lack of deep bass, and it hurts my ears if I try to turn it up.
Roon is configured correctly to pass through audio, and it's giving me the Purple light showing hirez is working(not that that matters).
Is HDMI the most likely culprit?
How do you guys manage to get decent sound out of your Windows HTPC and into an AVR?
Laptop doesn't have optical out, and even if it did, I also want to pass video as well. I have another Denon AVR with HDMI Arc in another room. Is there anyway that could be used to help? I would just try it, but unplugging all my sources out from behind my rack is gonna be a huge pain, since everything is zip tied and super neat , but if it's worth trying, I'll do it. I'd still be going HTPC ->(HDMI or USBc) -> TV -> HDMI ARC -> AVR. Wouldn't the output on the HTPC still be the limiting factor. I don't understand digital audio at all.
Also, I've been using my PS4 and Nintendo switch via HDMI into the same AVR and I've never noticed bad sound quality there, though perhaps that's just because I've never had anything to compare it to.
I wanna make this work, cause I've always wanted a HTPC for the many benefits it brings. Plus, that's the entire reason I bought this new machine .
