How durable is a paper cone driver?
Pearljam5000
I've read that some Genelecs (and obviously other brands too) use paper cone drivers (mostly woofers obviously)
How durable are they? Psychologically it's hard for me to even consider buying a speaker with that kind of a driver.
bluefuzz
The enemy of paper is damp. As long as you don't put your speakers in the bath you'll be fine. I have paper cone drivers from the 70s that are as good as new. All cone materials are a compromise of some sort. While an aluminium cone, for example, may be theoretically more durable than paper it still needs to be joined to the surround in some way which is a point of failure. Glues can turn brittle, foam can disintegrate, rubber can go hard or sticky and it's an open question how long any of the modern composite materials will last. Paper is a very durable material if treated well. There are books made from cotton rag paper from the 15th century that look like they were made yesterday.
Killingbeans
Bjerringbro, Denmark.
As long as you don't live in a damp cave, there's nothing to worry about. The surround, and possibly also the spider, will crumble long before the cone starts to deteriorate ;)
Kvalsvoll
Norway
The only drawback with paper is marketing - can not claim expensive and potentially dangerous to health materials.
Paper cones can be treated so they can hold up even in damp condition, and for outdoor use. How well, I can not say, likely there are differences among manufacturers also.
Never had any issues with paper cones, they seem to last forever, if mechanical destruction is avoided.
Katji
Speaker cone material an interesting subject. Complex. Various materials, composite materials that have been tried. Difficult to achieve consistency in manufacturing of some plastic materials.
... New High-Performance Cone and Diaphragm Technology
This article was originally published in Voice Coil, February 2019.
Head_Unit
At one place I worked, Ford Motor demanded they do more basic research. One of the things we were looking at was cone profile, for example tapering the cone thickness. The problem with these investigations was that every idea required tooling cost which was a lot. Ford business declined...therefore so did the research :(
Doodski
Considering I accidentally ran a Carver M1.5t full out with no subsonic filter and the turntable feedback was so loud it shook the building upstairs in a large building and the woofers in a Klipsch Cornwall took it without damage I would say that paper/pulp/fiber is pretty tough. 350 Watts per channel of feedback is no easy feat to absorb for any woofer let alone paper/pulp/fiber. Klipsch calls it a fiber-composite cone woofer.
Don't forget about those classic car guys,
They have their shows and the 50 year old classic cars include the 50 year old classic paper cone speakers in the dash. The absolute worst environment for speakers is cars, incredible heat, brutal cold, a constant pounding from road vibration and speaker abuse from horny teenagers on hot humid nights. (You know who you are!) Those basic paper cone dash speakers were never designed to last for half a century but they keep plugging along--not bad for something that was an after thought. Those paper cone speakers stuffed in ceilings in malls, stores and buildings playing elevator music 15 hours a day for 30+ years with no problems.
Paper/pulp or doped paper is some tough stuff! Those huge cement columns you see are formed with cardboard tubes--people will use those basically paper tubes and install 18" subwoofers to make cylinder subs. Those things can be hammered at extreme high SPLs for many years with no issues as long as you don't get them wet. As another posted quoted, paper books last many centuries without issue and scrolls have been found that are well over 1,000 years old.
Paper comes from wood pulp and wood is still cool from the last time I paid attention. How long will more modern materials last? Well, foam surrounds were "modern" back in the day and millions of speakers died from foam rot. Since there is far more than just the cone, you have adhesives holding things together, spiders holding the cones, the tensile leads, the voice coil must stay in alignment so how long do those adhesives last? Many paper cones with accordion surrounds make it 50 years or more but how long will a rubber surround last in a boiling car?
A lot of doped paper cones have all sorts of materials holding them together to provide damping, make them stiffer and so on. My professional drivers tend to have a sheen on them which indicates some form of coating to prevent either water or UV damage. I was eyeballing a 21 inch touring grade arena subwoofer complete with neodymium magnets, dual spiders, 6 inch voice coils and all that jazz...give you over 130dB and it used a doped paper cone and cloth accordion surround. $750 just for the driver, the huge cabinet and 2KW amp is extra (of course!)
The reason doped paper cones are used is because they work. Why do they use aluminum baskets instead of titanium or carbon fiber--geez, aluminum is used to make beer cans! Freakin' tweeters are loaded with plastic and why don't they silver coat pedestrian lowly copper voice coils? Ya know, those stupid audio people use basic steel screws to hold in the drivers--same stuff you can get at Wally World! Actually, some fools purchase brass screws to replace the lowly steel ones and claim it improves the sound--and you can tweek the sound by loosening or tighting the brass screws. I was thinking I could sell them titanium bone screws $$$ since if they are so far gone off the common sense train with brass, might as well rob them of the rest of their money. My father told me the most dangerous thing is an idiot with money, I am helping the world by removing that money. :D
A lot of it has to do with marketing, plastic was superior, graphite in the plastic was even better, kevlar, aluminum or titanium cones (they do exist!) and of course carbon fiber gets it's buzz. If you want to be uber cool...wait until Graphene rolls out. That stuff can be made and configured to actually do something besides creating a buzz. Graphene voice coils are electrically and thermally superior to copper, graphene formers, graphene cones, graphene surrounds and of course...graphene cones--well, once they figure out how to make that material in mass quanities that is. In reality, by the time that happens you can get a Neural Link brain implant and transfer sound directly to the brain and bypass the ears all together. That should be rolling out in 2025 so best to start saving your money for that as in 10 years having an audio system that is transmitted through the air through your so low fidelity ears will be laughable. Don't forget the bull horn--yell at those pesky kids with their Neural Links and don't forget to scream get off my lawn!
In summation, quit wasting time worried about the things you can see--the magic is in the things you can't see! Since I am an electronics guy, I've fixed many fancy cone speakers over the years and they were pretty! Well, until you removed the drivers complete with small magnets, small voice coils, low Xmax spiders, thin stamped frames and fancy trim rings to hide the cheezy frames (of course) I fixed a Bose 901 back in the day--the guy was shocked with how cheezy those drivers were--I though the three screws was a nice touch to save pennies. :D I love the smell of fiberboard and plastic in the morning--it smells like dumpster bait. At least the replacement 4.5 inch full range was only 14 bucks--the one thing Bose was reasonable with and parts were available. The oldest speaker I ever worked on was built in 1963... it was far older than me but the paper cone woofer was replaced in 1978. That old fully horn loaded speaker is still plugging along with a 57 year old compression driver tweeter and a 42 year old 10" paper cone woofer--with a fancy 12dB/Octave 800Hz metalized polypro passive crossover designed and build by me. (Chix dig metalized polypropylene 1% capacitors!) The end user stated it sounds better than it ever has (had a 6dB/Oct cap and coil crossover that caused huge compression driver distortion) That speaker is now so old it has been proclaimed "cool".... I told him I took the compression driver apart and it smelled like pot smoke and women with loose morals--yep, grandpa had a lot more fun than I did in my 20's! :D The guy fell for it "Really, you can still smell that?" Those speakers are used in an HT system complete with plenty of parametric EQ, room correction and measurements. He uses a BluRay player and streaming--no record players, reel-to-reels, cassette decks, 8 tracks and whatever--he is not into "retro" because he IS retro! :)
Paper--it is not just for 420 anymore--enjoy your day!
Katji
hahahahah Classic. :))
> "and of course carbon fiber gets it's buzz.
What about Kevlar. Cut-resistant, knife-resistant.
tvrgeek
North Carolinia
Am I missing something? Is this April Fools day?
BTW, a great many off those classic car speakers had cotton surrounds and spiders. Paper is fine, but the surround is completely gone.
( TVR, MGA, MGB, MGB-GT, Spitfire, Morgan, Stag) Of course, with British cars, the paper is usually damaged due to water. Do you know the difference between a British roadster with the hood (top) up and the hood down? If it is down, the carpet dries out faster.
Paper can come from any number of natural fibers. Wood being only one of them. Paper is a generic term for felted natural fiber composite.
mhardy6647
Multiple paper cone drivers here that are more than 60 years old and are in good working order.
I know folks regularly running drivers older than those mentioned above, too.
My long-time daily drivers (Altec 604E Duplexes) date from the mid-late 1960s and sounded (and still sound) mighty fine.
Doodski
How old is the oldest paper book, 500 years or so ?
The Epic of Gilgamesh
The Epic of Gilgamesh is the oldest known piece of literature in the world. Written in 2100 BCE it predates Homer's Iliad by 1500 years. The epic is a rich literary text that explores themes of honour, glory and human mortality.
thewas
But not on paper ;)
https://en.wikipedia.org/wiki/Epic_of_Gilgamesh
The first papermaking process was documented in China during the Eastern Han period (25–220 AD) traditionally attributed to the court official Cai Lun.
https://en.wikipedia.org/wiki/History_of_paper
