audio2design
- Joined
- Nov 29, 2020
- Messages
- 1,769
- Likes
- 1,842
I was asking whether double down is the attribute because that is what is published in spec but there may be a new attribute that is not yet found or published that explains the better dynamic range.
It is not the metric.
It is almost completely meaningless. What matters is how much power your amplifier will put out at the lowest impedance of your speakers at an acceptable level of distortion, and even that may not be the most important unless that peak is in lower frequencies as the highest power peaks in music are rarely at high frequencies.
If your speakers don't go down to 1 ohm, what do you care about the power at 1 ohm. In fact, an amplifier that does not double down in power down to 2 ohms or 1 ohm may be able to support louder peaks with your speakers.
Let's say your speakers never dip below 4 ohms. You have two amplifiers, 1 - 200 watts at 8, 400 at 4, 800 at 2, 1600 at 1. Lets say you have another amplifier 300 at 8, 600 at 4, 750 at 2, 650 at 1. Which will play louder on your speakers? The 2nd one. Why? Because it can hit 600 watts at 4 ohms, versus the other that can only hit 400.
Apparent, real, reactive power can almost be taken out of the equation w.r.t. amplifier power ratings. You need voltage to excite current, and the amp that does 600 watts at 4 ohms has more available voltage (likely) than the amp that can only reach 400 watts.
Why an amp does not double down, can be varied. A pure class-A may not because it just down not have enough current. A class-AB may not due to stability and/or hold up capacitance / power supply limitations. A class-D may hard limit current to prevent inductors saturating or to protect output devices. None of these indicate that prior to the amplifier entering clipping that it will not work properly.
To much of this is just marketing BS meant to confuse the less technical and even the pseudo technical get pulled in because it almost sounds right.
