dc655321
- Joined
- Mar 4, 2018
- Messages
- 1,597
- Likes
- 2,235
I use an SMSL iDEA primarily with my FLC8S in-ear monitors, and at home I now use a Topping NX4 DSD with a set of Massdrop HD6xx cans.
Prior to getting the NX4 a few weeks (months?) ago, the iDEA was used to power both earphones without complaint. IMO, the iDEA can drive the hd6xx louder than I like to listen.
I was and am still curious about how loudly I listen to music through my headphones. Am I consistent about volume as I switch between headphones and DACs?
Since I don't have a way to accurately measure the SPL I listen at (other than jamming my earphones into my iphone running an SPL app!), I thought perhaps I could glean some information by looking into the voltage ranges I set my sources to. Plus, I just got an Analog Discovery 2 to play with, so this gives me an excuse to kick the tires and maybe quantify some of the answers to my questions.
I wrote some software on top of the AD2's Python API to affect data acquisition. This was useful mainly to acquaint myself with some of the API's capabilities (and warts!). I used a 1 kHz tone into an open load through the iDEA and the NX4 in the following measurements. The AD2 was hanging off of my Thinkpad X1 (last year's model) running Linux, battery powered.
In the plots below, the dots represent dB as a function of volume position, while the lines are voltage as a function of volume position.
First up, is the SMSL iDEA. This has simple up/down buttons that discretely alter the volume in 20 steps:
I usually listen to the FLC8S at 5-6 clicks and the HD6xx at 14-16 clicks. In terms of voltages, that's about 0.020-0.028 Vrms for the FLC8S, and 0.260-0.450 Vrms for the HD6xx. Note the channel imbalance at minimal volumes here. Some of that is a 2-3 mV offset in the AD2. Clearly I need to do some calibration and try to eliminate that. Also note the different slopes (rate of volume change) before and after step #5.
Next up is the NX4 DSD in low gain setting. This unit has an analog pot for volume actuation.
The offset present in the AD2 cannot account for much of the channel imbalance visible here (and audible!) at low volumes. Note that Channel 1 and 2 appear almost "stuck" at some minimum value. Using the FLC8S with this DAC is not as seamless as I would like, as the channel imbalance does not resolve until well into my typical listening volumes. I can always turn down the volume in my player (Cmus - i'm a command-line junkie) to compensate for this, but of course I would rather not have to...
on
The issue is resolved just prior to 10 o'clock on the pot, but this is already at significant volume. Steps 7-9 for Channel 2 above correspond to 0.017-0.037 Vrms, bracketing the values I gravitate towards when using the iDEA.
I use a pot position of around 12 o'clock with the HD6xx on the NX4. Here, 12 o'clock on the pot is step #15, with a voltage of 0.450 Vrms. That compares well with my volume position on the iDEA. Of course, really great songs get cranked up a little bit more .
on
