How shape/material of speaker footers impact their effectivness
Don Hills
Wellington, New Zealand
... Townshend's idea is a bit different than other people. They contend the speaker sends out bass notes, which come back to a speaker via the floor causing movement. Enough movement to equal the movement of tweeters which can smear or blur sound. So decoupling is to prevent this from occurring. They have this video to show what they have in mind. Also in some cases vibration from other sources can interfere with the speaker providing sound cleanly. My question would be if the amount of movement is enough to really make an audible difference. ...
It's not enough to assume that the baffle (and therefore the tweeter) moves back and forth a similar amount to the movement of the tweeter diaphragm. You also need to take into account the frequency of the movement. In theory, it would impart a doppler effect on the tweeter output. In practice, it's simply inaudible. For proof, look at any fullrange driver, where the problem of bass moving the treble source back and forth is hundreds of times worse. If it was that audible, fullrange drivers would sound awful. Or any coaxial driver, where the cone forms a waveguide for the tweeter.
March Audio
Albany Western Australia
Yes, you can see sidebands on tweeter output, which was the next test I was going to do.
March Audio
Acoustic measurement with 100Hz and 5kHz
Noise floor (Fs not ref 20uP)
100Hz Bolted Mount
5kHz Bolted
100Hz + 5kHz bolted
Zoomed - 100Hz sidebands
100Hz Sorbothane feet
5kHz Sorbothane
100Hz+ 5kHz sorbothane
zoomed sidebands
This should demonstrate (along with the previous post) that the baffle is vibrating pretty much the same regardless of how the speaker is fixed to the stand.
The sidebands on the acoustic measurement demonstrate Dons assertion that a Doppler effect is happening and the tweeter is moving at 100Hz caused by the woofer.
RayDunzl
Central Scrutinizer
Riverview FL
Have you considered using different test frequencies so the products don't overlap the noises in the noise floor and stand out on their own?
Nightlord
southern Sweden
How much are you playing when testing this? A single period of the frequencies?
I'd probably tested what happens with a sinc if I could.
March Audio
I have but I am limited for time, the real purpose was to show the sidebands on the tweeter indicating its vibrating whatever the speaker mount is doing.
March Audio
Its a 65536 point FFT linear averaged - you can see the avg number on the plots, so its measuring for some time.
Don Hills
Thanks for doing this. Hands on beats hand waving hands down.
Blumlein 88
Perhaps Nightlord is asking for the equivalent of a Dirac pulse. A good hammer blow to the speaker should do it. :) Oh, no please don't do that.
Yes, it does appear doppler distortion is alive and well. Such effects seem likely to overwhelm the jitter sidebands at picosecond levels everyone worries so much about.
I have an old DIY speaker building handbook from the 1960's, and they spent half the book going on about Doppler / FM distortion of the tweeter.
March Audio
Doesn't say what you played for that, so I assumed it to be by hand.
I literally gave it a wack with a soft mallet. The impact is like a stimulus at all frequencies.
Do this a lot in the vibration testing I perform in my job.
The second graph was the speaker playing pink noise, again a wideband stimulus. Thiswas fairly consistent with the bump test
One thing I wondered about, at least some of this modulation must be due to the acoustic pressure on the tweeter diaphragm and not just direct vibration???
Nightlord
southern Sweden
I think that a single (or half) period of a sine - and progressing that down in frequency to find when you pass below resonance of the system would be interesting. That would work continuous as well, but if we want to see the difference in decay time, it's better if it's limited.
The feet I use will put the resonance point at 7Hz or lower... so if I would do it, I'd start at say 20Hz and go down 1Hz at a time and see what happens when you pass it. How you find at what point you should do the same for a spike based setup is (for me) more difficult, I have no idea how much higher that is. For that the dirac or whack might give the answer, and having found the resonance point for the soft feet, there might be a clue in whack/dirac graph for the soft feet once you know what to look for?
Sal1950
The Chicago Crusher
Central Fl
Thought I'd pass along a Cheapskate tip. While gathering items to protect my new wood floor from furniture, etc; some time back I came across these at Lowe's that are perfect for going under spikes. I've got them under both my subwoofers. At $4.97 for a package of 8, they're a whole lot cheaper than the fancy-dans being sold by the audiophool retailers. ;)
https://www.lowes.com/pd/Waxman-8-Pack-Brown-Round-Felt-Pads/3027868
Blumlein 88
Dammit Sal! I was planning on selling those rebadged as Blumlein soft points. One way diode action in a soft floor safe finish and constrained mode damping decoupling disc in one. $497 for 8. I know, I know compared to some items a 100x mark up isn't much. Doesn't matter now. You ruined it. There goes my chance to pocket a bundle and move to Florida.
:p
I'll have to go with my hocky puck feet now. Those are such stiff rubber though you need 1000 lbs of speaker for them to be effective. I use them at jacking points on my sports cars.
Sal1950
The Chicago Crusher
Central Fl
March Audio
As shown the feet arent going to stop the baffle vibrating so we are looking at a different issue here, that of vibration transfercinto the floor.
I will do some further measurements on the stand itself to show the difference between bolting and sorbothane.
