How to compute parameter values (frequency, gain, Q-value) to EQ a loudspeaker
ironhorse128
I would like to be able to compute parameter values (frequency, gain, Q-value) to EQ a loudspeaker or headphone. I guess it is a more or less complex optimization problem given the frequency response of the loudspeaker/ headphone and a target curve.
I know that there are some programs (e.g. REW) that lets you do that. I would like to read up on the math and algorithms behind these. I did not find suitable resources while my google search, so I thought I might ask ASR.
My final target would be to program a web-tool that lets you upload frequency response to compute a suitable EQ configuration (frequency, gain, Q-value).
So if anyone knows a good start to read up on this topic (books, web-resources, open-source projects, programming libraries,…), please let me know.
This is the form of the "bell-shaped" filter transfer function I usually use. (Note that the gain given in the equation is NOT in dB.)
The response of the transfer function Ĥ(s) at a given frequency can be computed by substituting "s" with "j*2π*f", where "j" is square root of -1, "π" is 3.1415926..., and "f" is frequency in Hz. The result is a complex number. Its magnitude is the amplitude, and angle (argument) is the phase. When cascading multiple filters, just multiply the complex responses of each filter to get the combined frequency response.
Here is some python code to calculate and plot the FR of 2 of these filters, and when they combined.
Python:
import numpy as np
import matplotlib.pyplot as plt
def peq_tf(gain, bw, f0):
      Return transfer function of a 2nd order bell-shaped filter as the coefficients
      of the numerator and denominator polynomials.
      Call signature
        num, den = peq_tf(gain, bw, freq)
      Inputs
        'gain': amplitude at center frequency, 1 = unity gain, >1 = boost, <1 = cut
        'bw': bandwidth in octaves
        'f0': center frequency in Hz
      Outputs
        tuple of ('num', 'den')
        'num': transfer function numerator polynomial coefficients, degree 2 first
        'den': transfer function denominator polynomial coefficients, degree 2 first
    w = 2 * np.pi * f0
    num = np.array([1, 2*np.sqrt(gain)*np.sinh(np.log(2)*bw/2)*w, w**2])
    den = np.array([1, (2/np.sqrt(gain))*np.sinh(np.log(2)*bw/2)*w, w**2])
    return num, den
def peq_fr(tf_coeff, freqs):
      Compute complex frequency response of a 2nd order filter.
      Call signature
        fr = peq_fr(tf_coeff, freqs)
      Inputs
        'tf_coeff': tuple of (num, den) specifying the polynomial coefficients of the
                    transfer function, degree 2 first
        'freqs': frequencies at which the responses are computed, in Hz
      Outputs
        The complex frequency responses of the filter at 'freqs'
    j_ws = 2j * np.pi * freqs
    num, den = tf_coeff
    return (num[0]*j_ws**2 + num[1]*j_ws + num[2]) / (den[0]*j_ws**2 + den[1]*j_ws + den[2])
# PEQ filter 1 -- center freq 2000 Hz, bandwidth 1.0, gain 2.0
filt1_params = [2.0, 1.0, 2000]
filt1_tf = peq_tf(*filt1_params)
# PEQ filter 2 -- center freq 200 Hz, bandwidth 3.0, gain 0.5
filt2_params = [0.5, 3.0, 200]
filt2_tf = peq_tf(*filt2_params)
# The frequencies at which we want to compute the filter responses
freqs = np.logspace(np.log10(20), np.log10(20480), 501)
# Compute the complex frequency response of each filter and their combined response
filt1_fr = peq_fr(filt1_tf, freqs)
filt2_fr = peq_fr(filt2_tf, freqs)
filt_combined_fr = filt1_fr * filt2_fr
# Plot the magnitudes of the complex filter responses
fig, axs = plt.subplots(3, 1, figsize=(5, 8), sharex=True)
axs[0].semilogx(freqs, np.abs(filt1_fr), c='C1', label='Filter 1')
axs[1].semilogx(freqs, np.abs(filt2_fr), c='C2', label='Filter 2')
axs[2].semilogx(freqs, np.abs(filt_combined_fr), c='C3', label='Combined')
for ax in axs:
    ax.legend(loc='upper right')
    ax.grid(which='both', axis='both')
    ax.set_ylim(0, 2.5)
fig.tight_layout()
plt.show()
Plot output
I have no real experience on how to find the gains, band-widths (or Q) and center frequencies of a series of these filters to fit the response to a target response. I guess the naïve approach will be to simply feed the problem into a nonlinear regression solver, using some reasonable initial guesses, and with no guarantee of success. There are probably better methods.
Sorry to necro this thread. I was approached by a new member on how to compute the frequency response of low and high shelving filters (similar to what I did for peaking filters in post #2).
Below are the transfer functions I modified from the ones provided in the link to "Audio-EQ-Cookbook.txt" given in:
And my Python code to test them out:
Python:
import numpy as np
def bw2Q(bw):
      Return Q given the bandwidth (bw) in octaves
      Reference: RaneNote 167 (PDF page 5)
                 https://www.ranecommercial.com/legacy/note167.html
    return np.sqrt(2**bw)/(2**bw - 1)
def Q2bw(Q):
      Return the bandwidth (bw) in octaves given Q
    return (2/np.log(2))*np.log(0.5*(1/Q + np.sqrt(1/Q**2 + 4)))
def low_shelf_tf(gain, bw, f0):
      Return transfer function of a 2nd order low shelving filter as the coefficients
      Reference: See link to "Audio-EQ-Cookbook.txt" in
                 https://www.musicdsp.org/en/latest/Filters/197-rbj-audio-eq-cookbook.html
      Call signature
        num, den = low_shelf_tf(gain, bw, freq)
      Inputs
        'gain': amplitude at DC, 1 = unity gain, >1 = boost, <1 = cut
        'f0': conrner frequency in Hz
      Outputs
    Q = bw2Q(bw)
    A = np.sqrt(gain)
    w = 2 * np.pi * f0
    num = A * np.array([1, (np.sqrt(A)/Q)*w, A*w**2])
    den = np.array([A, (np.sqrt(A)/Q)*w, w**2])
    return num, den
def high_shelf_tf(gain, bw, f0):
      Return transfer function of a 2nd order high shelving filter as the coefficients
      Call signature
        num, den = high_shelf_tf(gain, bw, freq)
      Inputs
        'gain': amplitude at infinite frequency, 1 = unity gain, >1 = boost, <1 = cut
      Outputs
    Q = bw2Q(bw)
    A = np.sqrt(gain)
    w = 2 * np.pi * f0
    num = A * np.array([A, (np.sqrt(A)/Q)*w, w**2])
    den = np.array([1, (np.sqrt(A)/Q)*w, A*w**2])
    return num, den
      Call signature
      Inputs
      Outputs
    num, den = tf_coeff
# Filter 1 -- low shelf @ 200 Hz, bandwidth 1.8997 (Q = sqrt(0.5)), gain 2.0
filt1_params = [2.0, 1.8997, 200]
filt1_tf = low_shelf_tf(*filt1_params)
# Filter 2 -- high shelf @ 2000 Hz, bandwidth 3.0 (Q = 0.40406), gain 0.5
filt2_params = [0.5, 3.0, 2000]
filt2_tf = high_shelf_tf(*filt2_params)
axs[0].semilogx(freqs, np.abs(filt1_fr), c='C1', label='Low Shelf')
axs[1].semilogx(freqs, np.abs(filt2_fr), c='C2', label='High Shelf')
for ax in axs:
    ax.set_ylabel(r'$\left| \frac{V_{out}}{V_{in}} \right|$')
    ax.set_ylim(0, 2.5)
axs[2].set_xlabel('Frequency, Hz')
fig.tight_layout()
plt.show()
Perhaps others may find it useful.
