How to connect HD800s headphones for my AppleTV 4K Dolby Atmos?
AmalfiMan
I been searching through previous posts and couldn't find any info on how to best use my HD800s headphones, to listen to content from my apple device (ATV4K). I was hoping to take advantage of the Dolby Atmos now available on ATV4K to watch netflix, HBO.
--The ATV4K has only 1 HDMI port.
--The LG CX OLED TV only has a stereo port, no RCA ports.
--I do have a Topping EX5 Dac/Amp, connected to my PC
Any ideas, other than buying a AV Receiver?
mrbungle
Boston
Last time I checked, Dolby Atmos for headphones outside the Music app was still exclusive to supported AirPods and Beats. Apart from that, Bluetooth via Topping Dx7 Pro is working perfectly for me with the ATV 4K.
AmalfiMan
AmalfiMan
Ok thanks. My topping ex5 is their newest dac/amp and with BT 5.0. It sounds bad when BT to my iPhone 11. But I will give it a shot with the AppleTV.
I also will try the stereo jack on the TV.
NiagaraPete
You need headphones that are Atmos compatible and your HD800’s are not.
mrbungle
Boston
Probably a license thing. Maybe in the future they make it possible to buy one from the App Store as they do for the Xbox. Not sure your LG comes with a Atmos headphone license, probably not. And probably not possible to buy one either.
BT shouldn’t sound bad.
AmalfiMan
AmalfiMan
****Update****
Got it to work. The EX5 BT did pair with the ATV, and sounds great. Because the HD800s is more comfortable and sounds more natural than the AirPod Max, it actually sounds better than the Max with Atmos.
Snoopy
Silly question - how does a wired HD800s work with airplay?
Roopieee XL and a rasberry pi 4 support airplay.
My MacBook does airplay.
But you won't get Dolby Atmos.
I use airplay from my apple tv4k to my Cambridge CXN V2.
And With roopieeXL to my rasberry pi4 that is connected to my headphone setup.
NiagaraPete
Isn't BT about 1/3rd the quality of a CD? Kind of a waste for HD800's.
AmalfiMan
AmalfiMan
I tested it against the airpod max, which obviously uses dolby on ATV4K. The HD800s sounded better as in more natural. I didn’t miss any details and it was more comfortable for long periods of time.
However the max, did amplify loud scenes more and maybe more immersive. But with the Max, I need to take it off every 30 mins as its clamping. the sound is a tad more artificial.
NiagaraPete
However the max, did amplify loud scenes more and maybe more immersive. But with the Max, I need to take it off every 30 mins as its clapping. the sound is a tad more artificial.
I get that the Airpod Max compared to the HD800's are crap Atmos or not. My point was if I owned HD800's I'd want to make sure that my source was the best it could be. Like they say "garbage in, garbage out".
AmalfiMan
AmalfiMan
so it a high end receiver with dolby atmos would get the most out of the HD800s? Any recommendations? Not that I will get one but just curious.
NiagaraPete
No. HD800's are not Atmos compatible.
NiagaraPete
Here you go:
While you can get Dolby Atmos audio with any headphones using Dolby Atmos software, you can also improve the experience by selecting special multi-driver headphones. These multi-driver headphones effectively mimic what you get in a Home Theatre set up by placing audio drivers in the unit.
There is no way to get all 36 drivers in a headphone as you get in a movie Cinema that is Atmos-enabled. The Dolby Atmos cinema in Trafalgar Sq. as over 400 atmos speakers -try fitting that in a headphone!
mrbungle
Boston
Maybe 1/3 of the uncompressed bandwidth. It’s still over 250 kbps AAC. Given that most people can’t distinguish 192kbit MP3 vs red book, and that all streaming content is compressed anyways, it’s totally fine.
NiagaraPete
So you spend $1800 on headphones to listen to mp3's? Over kill I'd say. Unless $1600 for comfort justifies it.
Doodski
I did extensive comparison of MP3's to lossless songs of the same release and I could not hear a difference using headphones. I have one Pink Floyd Money lossless file that does sound better although it is 2666kbps.
NiagaraPete
For me it's fatigue. I last about 20 minutes.
