Peib
Hello!
I’m considering to buy both topping e30 and l30 in order to pair them with my beyer dt1770pro. The problem is I want to keep using my speakers, which are connected to an integrated amplifier. I want to use the E30 not only for headphones but also for speakers and I dont know exactly how to connect them.
My idea is connecting PC to E30, then E30 (dac) to L30 (headphone amp), and then to the integrated amplifier. Does this way allow me to use the headphones connected to L30 and speakers without losing quality? Both using E30 as dac?
Excuse my English if it’s bad
Thanks!
EDIT: if I decide to go by the way of Y splitter
Tell me if Im wrong: I should buy two of these. Then I'll have to connect to the purple side (female) the red cable rca output from E30, and to the purple side of the other splitter I'll have to connect the white cable rca output from E30. After that, the 2 outputs from the white cable connect each one to each white audio input from the L30 and the integrated amplifier. Then, connect the other 2 outputs (red, from the other splitter) to the red input audio of the devices. Is that the way to proceed?
https://www.amazon.es/dp/B01D5H8SGC...jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
Thanks!
