Hi, I have a project to convert a cheap pair of passive speakers into a cheap pair of active speakers through a cheap Aliexpress board stereo+bluetooth amplifier. The problem is I have to open the speakers to make the connections, but it doesnt seem to me there is a way to do it without destroying them. Also Don't know how I would have to glue the parts together again.
Here some photos of the speakers:
I thought maybe if with a screwdriver I make some pression on the corner of the round plastic connector, maybe I would be able to extract it and acces the cables important for me... but it didn't work:
So it seems to me my only option is to separate all the walls and then rejoin them. Can you please give me some advice to make it end well?
Thanks
EDIT:
It worked:
But still I need to be able to screw the board to the top interior of the speaker in order to be sure it will never drop.
By the way, is that condensor there doing the work as a frequency filter? The yellow cables go to the tweeter
Thanks
EDIT:
It worked:
