How to EQ from SPOTIFY
FrantzM
Hi
I converted an old PC as my music source. I will in due time install the ROON core on it it . I also listen from my work PC when I am traveling or in my office
Question:
How do I eq from SPOTIFY? on foobar and ROON, not a problem , .... with SPOTIFY no EQ. Output is USB from a PC, I'd like any source to simply be EQ ... from the PC be it SPOTIFY , ROON or Foobar. I would like to have one EQ application through which all music go. Headphones are my 3 mainstays: HiFiman HE-560, Stax-SR-009 and SONY WMX-100 Bluetooth NC which I use once in a while with my PC when I want to isolate myself from the ambient noise.
Thanks in advance
daftcombo
Have you considered using a system-wide EQ like Equalizer APO?
I was going to answer EqualizerAPO as well.
It will be bypassed by ASIO, so won't be applied to Foobar2000 if you select an ASIO driver on it for instance.
pierre
Switzerland
Hi
Question:
How do I eq from SPOTIFY? on foobar and ROON, not a problem , .... with SPOTIFY no EQ. Output is USB from a PC, I'd like any source to simply be EQ ... from the PC be it SPOTIFY , ROON or Foobar. I would like to have one EQ application through which all music go through. Headphones are my 3 mainstays: HiFiman HE-560, Stax-SR-009 and SONY WMX-100 Bluetooth NC which I use once in a while with my PC when I want to isolate myself from the ambient noise.
Thanks in advance
DDF
Is this a software?
I will try EqualizerAPO immediately
I’ve heard to also try peace GUI with it. They’re in my to do list for the same reason as you.
gvl
SoCal
You can use JRiver for that. For Spotify you need to enable the WDM driver in settings and make it the default sound device on your PC, for others they can also use the WDM driver directly in exclusive mode or there is also a virtual ASIO device JRiver installs if memory serves. Then when you play in your applications JRiver gets the audio stream and there you have a pretty powerful DSP engine, EQ including. JRiver must be set to output to your actual audio device using WASAPI or ASIO.
Yes this is what i did when I was learning about all this last month. Jriver is your playback device, and it was outputting to my dac/amp via USB.
F
FrantzM
I tried the APO EQ plus Peace GUI. The combo works well.
I don't have plan to use JRiver...
gvl
SoCal
You may want to reconsider if you're a serious Spotify premium user, as JRiver allows to bypass the system mixer and improve sound quality, from my experience anyway.
DDF
Just installed EQ APO as well (didn't bother with peace gui). Using Audacity I verified that the EQ applied was identical for Tidal, Spotify and foobar. I set the default in windows to 44.1 and 24 bits as everything I play (and streaming) is 44.1 so there is no resampling and it sounds great, I should have done this much earlier!
gvl
SoCal
No resampling? Are you implying the EQ it performs is bit accurate?
DDF
There's no such thing as "bit perfect" eq. The Windows resampler can lead to bad problems but if set to the correct sample rate, its avoided. Windows will add some dither but thats well done. I've taken measurements and am very satisfied.
When you talk about Windows adding dither, can you elaborate? Sorry, I'm still learning all this. I setup this way and just stream mostly through tidal hifi, and I'll manually change to 24 bit when listening to mqa tracks. I did the jriver thing but it just seemed like way more inconvenience than it was worth. Maybe if I had a larger collection of downloaded files vs streaming. Plus tidal can be set to exclusive mode if you wish anyway, but I prefer to use a little eq
VincentYyl
The Equalizer on Spotify sucks. I never get a satisfying effect. But I found the EQ from Poweramp is super useful, and so I get the whole album from Spotify with spotify album converter and play the album on Poweramp, to be honest, that built-in eq is staggering.
