How to fine tune my kef r3?
  • Thread starter Deleted member 51459
  • Start date
Chrispy
PNW
i dont have speakers stand and no other place to put speakers..
terminals are tight!
i personally inspected them several times i checked them for speakers and amps as well..
70RMS mean way way less not sure how much for my car 400w rms means less than 40w for example... not sure how its measured.
RMS is fake WATTAGE.
You must compare wattage at same spec....were the two ratings for full band (20hz-20khz)? at a reasonably low and equivalent THD? The wattage alone doesn't mean much without that info....
D
Guest
Also, looks like you have a subwoofer enabled. If you don’t have one, disable it:
Also go though all the DSP settings, make sure the front speakers are set to large, and the rest are disabled.
Thanks sub is removed and disabled... it doesnt make any difference...
also changing front speakers too i am in stereo mode..
voodooless
Netherlands
This thing should actually do 70W in stereo mode full band with good enough distortion. If the thing is still functional, that should be plenty. I’ve ran R500’s with half of that and they went loud!
voodooless
Netherlands
That leaves the att settings then (page 17).
fieldcar
Milwaukee, Wisconsin, USA
How much real wattage my receiver can make then at 8ohm since you provided data for 6ohm ? if it makes 40w at 6ohm it should be less in 8 ohm i guess? I verified links and knobs are pressed correctly... if knobs are not pressed in the right way Speaker doesnt sound at all or it sounds only bass i tried that as well.
I'm sorry. My clip was from a Yamaha AVR with a similar model number. You do, in fact, have 70W@8Ohm.
The KEF R3 is a 3Ohm speaker, and this may be part of the issue.
D
Guest
So its still because of my crappy stereo receiver, i cant borrow other receiver but i plan to buy amplifier in the coming weeks, lets say 2-3 weeks depends where i got money /my salary as soon as i got salary i will buy 1 amplifier... because i need high end... i guess thats all this old home receiver can provide this is his limit...
cant handle these speakers properly..
https://audio-database.com/VICTOR/amp/rx-e100.html
here is what i found rca victor data base
Chrispy
PNW
I agree and when chatting with OP on pms told him to try that while he shops for a new amp (he has other threads on that). Could be it has not aged well, tho.
D
Guest
SMSL A-300 is a great ''starting'' amplifier.
i need reference class
something which will last me years and its well made, not some junk or crap, i like nad but they are cheaply made, not quality enough too bad sony,jvc and pioneer and others doesnt make any more decent amplifiers for stereo for home users...
i can get nad master series m33 , or nad c399 or nad c298 or something else like moranz model 30 model 40n.. or something else...
so its confirmed at 100% thats my receiver which makes me trouble.
Can someone clarify for me ,
should i listen to
bass boost off treble 0, and bass 0 or i should increase these ?
abdo123
Brussels, Belgium
Yeah it's just you have nothing working right now so you might just jump quickly to something and get ripped off.
The SMSL A-300 is a great ''transition'' amplifier.
D
Guest
Its chinese stuff which i cant buy in my country and i want to jump to the high/end reference class i will write it as company/accountant expense so it will not be rip off.
it will be deducated from the company taxes for the several future years.
Chrispy
PNW
should i listen to
Generally that would be best, to leave all off....if you did boost bass particularly it would cut into your amp power.
D
Guest
Bass boost is off treble 00 and bass at 00 , should i leave it that way or ? Sound is much worse compared to my naim muso 2, which is quite a shame.
Chrispy
PNW
Yes, leave all off or at 0 (assuming the dial is a +/- scale with 0 representing off)....
D
Guest
What does that mean? Except for “not crap”?
For the last 40 years i have bought 000 amplifier if i dont count my car...
i want something extremely high end its called lifetime amp...
voodooless
Netherlands
How did you get the JVC then?
None of that answers the question. Very few amps will really last a lifetime. They all contain components that age over time, no matter the price. “Extremely high end” means exactly nothing..
