How to Fix ESS Hump on SGD1 and LA-QXD1
Herbert
In some ways my question might not be fair, as Ben1987 put a lot of energy and good spirit
into the fix. But the pcb of both DACs are physically too big for my needs and
therefor I am stuck to the Khadas tone board.
In the moment of writing, I do not have Khadas´ published schematics with me and do not know what
opamps were used. But can this fix be done with the Khadas Tone Board as well?
All the best,
Herbert
Herbert
Hm-no one to do the math? I am not deep enough into electronics to calculate the ratio of the changed
values. Above Bens calculations, below the tone board unaltered...
Reactions: trl
captain paranoia
This hump seems to appear consistently on many ESS implementations.
Have ESS not discussed/addressed it in their application notes?
I recall trying to get their datasheet/appnote, only to discover they cannot be freely downloaded; that's an unusual stance for a semiconductor manufacturer. Not unprecedented, but unusual.
somebodyelse
The datasheets aren't freely downloadable, but some have leaked. The hump isn't addressed in the ones I've seen, and IIRC some manufacturers have said it isn't in the datasheets or known by their contacts at ESS (on khadas forum, and i think another source? Not sure...). This is consistent with the large number of manufacturers having a similar problem. It's possible there's a mode detailed document that they reserve for a select subset of customers under NDA, or that a select few have worked it out themselves. @Ben1987 's explanation here, and the somewhat guarded posts of another user who may be under NDA (don't have it to hand - in the ess hump thread) cover a component selection approach, while @IVX does it with config options so long as other analog requirements are met.
captain paranoia
Manufacturers usually go out of their way to allow their customers to get the best performance out of their products (the likes of AD, TI, BB, NS, LT, etc in the 'good old days' produced some excellent appnotes). I cannot understand why ESS would do otherwise. But then I don't really understand their datasheet policy, either.
ESS has not been on any help. Whether they help much larger manufacturers is unknown. But despite this issue coming to their attention last year, no effort was spent on their part to help resolve it.
They also have ignored my two separate outreach to them. Not even a simply reply. Nothing.
scott wurcer
Audio Luminary
I don't understand this issue at all, I knew Martin for years before he left to help form ESS and they invited me to an early listening session. This never came up, though Barrie Gilbert guessed at one of the things they were doing only to get a few smiles. Four+ years ago ESS invited me to tour the five (four?) major Chinese cell phone manufacturers since they all had an initiative to add a separate high quality audio chain with headphone driver. It was an opportunity to sell some customer premise ADSL drivers that had waning sales. This never came up in any context, even though I posted a plot here on how obvious the problem could be.
solderdude
The Neitherlands
View attachment 47773View attachment 47774
It is the absolute values (as well as the ratio) that is of importance. Bens schematic also has a second opamp stage which appears to have not been drawn as I don't think the TB has a 1.6k output R.
Doesn't look like anyone had measured and identified this issue until I ran into it. This may very well have included ESS.
captain paranoia
You would like to think that chips are tested properly. But then I've found three bugs in chips, unknown to the manufacturer, in a 35 year career. One of them took me over a month to pin down and develop a workaround. The manufacturer at least was helpful, and confirmed my diagnosis in simulation, and issued an errata note. Another bug also took a while track down, and turned out to be an undocumented edge sensitivity.
When you have the details of your own design in front of you, diagnosis of bugs usually isn't too hard; you can trace the circuit behaviour. When you have a black box, and have to probe the box by guesswork, it's a lot harder...
solderdude
The Neitherlands
There are manufacturers that used the same chip and did not have the IMD hump.
The hump is not caused by the chip but incorrect circuitry after the DAC chip.
When the chip is loaded correctly the hump is not there, assuming during development they used the correct load post filtering it would not have shown because it was not there to begin with, even when they measured (and assume they did) for IMD versus output level.
Pluto
Harrow, UK
Surely, if the load is critical it could reasonably be expected for the data sheet to flag that point and offer appropriate guidance in their reference design. So far, the evidence is suggestive of either...
i) they really did not know, and this caught them napping
ii) they knew but chose to keep quiet
Other conspiratorial possibilities exist.
mslim
The SGD-1 has just gone to the top of my list. The purchase link on Aliexpress shows the item in unavailable. It is either due to items being withdrawn pending upgrades (or it could be Covid-19).
Will the LA-QXD1 be similarly upgrade? There is no purchase link for this.
Herbert
I assume in Ben´s drawing the altered values in the second stage (between 7-6 and 1-5/2/3 are for correcting the output volume that has been altered in the I/V stage before? I do know almost nothing about electronics but as far as I understand the DAC only "sees" the load of the first opamp and this is where the hump is created…? So I assume in the Khadas schematic at least R45/R46 // R48/49 have to be altered as well to compensate for changes in volume?
BTW I whish and hope for the chinese people all the best...
JimB
California
You would like to think that chips are tested properly. But then I've found three bugs in chips, unknown to the manufacturer, in a 35 year career. One of them took me over a month to pin down and develop a workaround. The manufacturer at least was helpful, and confirmed my diagnosis in simulation, and issued an errata note. Another bug also took a while track down, and turned out to be an undocumented edge sensitivity. ...
I know, right? I found this twice - once with a die shrink of a counter chip, and once with an ADC. In both cases, the manufacturers did not know about the problems, but did own them once documented. They did not fix the issues, but they did call them out in subsequent datasheets.
Get a hearing test
How audible is it really. Some dacs have noise levels that are consistently above even the hump so it should be inaudible?
