How to identify Room Modes by measurement
Olli
I am looking for the optimal XO point for Subs. This is why I new to check for Room Modes. Unfortunately my room is totally non standard in its dimensions, so a Calculator W/D/H won’t help. Is there a way to identify Room Modes by measurement, preferably with REW?
RayDunzl
Central Scrutinizer
Riverview FL
Hipper
Herts., England
I can't seem to get
https://amcoustics.com/tools/amray
to do anything.
What I did was draw a shape on the graph. Say you want to draw a rectangle. Find a starting point, left click and hold down whilst drawing a line on the graph. When that line is complete release left click. Then draw the next line.
You can make any shape including angular lines but not circles.
Where you go from there I'm not sure. Click on '?' for more clues.
RayDunzl
Central Scrutinizer
Riverview FL
It didn't like Chrome here...
MediumRare
Chicago
You might need flash.
Next step, click on speaker to place your subwoofer. Click ear to place the listening position. Then you can select the main reflections or all reflections.
Willem
Just get a measurement microphone like the UMIK-1 and measure what is really happening. You will likely be horrified.
MediumRare
Chicago
Sure. This site is handy for finding unexpected reflections for potential treatments.
MediumRare
Chicago
Can REW do everything MathAudio Room EQ can do? What are the best room eq products?
ernestcarl
LOL. That was my impression at first, too. The awful truth is hard to accept -- in the first days and weeks -- then you later find yourself saying: "well, it's really not all that bad... maybe we can improve things a bit."
pozz
Слава Україні
Editor
Room modes (which depend on the room's dimensions) can't be fixed with room EQ, although those with irregular shape as the OP described have less chance of standing waves.
As @Willem said, measure and then adjust as needed.
Purité Audio
Industry Insider
Barrowmaster
London
You can reduce the energy of the bass peaks with EQ.
