pantera_rapida
- Joined
- Mar 30, 2021
- Messages
- 28
- Likes
- 8
I have a few questions around matching my tube pre-amp with different power amps, and also about running my amps bridged.
Recently I purchased a (used) Primaluna Dialog Premium tube pre-amp. It works and sounds great, and I have it running through two NAD 2200 power amps (bridged). A bit later I purchased a set of used speakers which are 90dB and 4 ohm. A few people have mentioned I should not be using the 2200's bridged with that setup (but it's ok with 8 ohm speakers). I've run this configuration (PL-2200-speakers) for about 2 months now without issue. I never go past 94dB peak in the room with whatever I'm playing.
I've been looking around for another amp (or mono blocks) that could provide the same power/performance as the bridged 2200s. So far I've had no luck. Running the current setup with the 2200s I barely have to put the PL volume past 9pm, it's plenty loud and everything sounds excellent. The music sounds full, rich, big 3D soundstage, detail, etc.
But after A/Bing a few different stereo amps, even one with 400w @ 4 ohm, for all of them I have to put the volume closer to 11pm in order to match the same dB level for the music as I do with the 2200s. Why is that the case?
Are the 2200s bridged putting out the power differently than these amps to require the volume to be set so differently? Is this a gain (or impedance?) issue on the Primalina side? I've seen some amps, like the Parasound A21+, that have gain dials on the back, which you can turn up to 31dB. Would this amp be a better match then for the PL? It rather limits the types/number of amps I can use with the PL if that's the case. How would I know which amps are more qualified?
Lastly, if the 2200s work so well bridged with the speakers, should I just skip looking for an amp and leave them running as is? I was contemplating having them updated (caps, etc.) as they are still original (1987).
