I do not understand how this is done. I appreciate if you elaborate further.It’s not AirPlay as far as I know. I am running Apple Music on the Appletv app and controlling it from the iPad.
I don’t really either. I start up my AVR and ATV. Then I use an IPad from the couch, open the Apple Music app (Just became an Apple Music suscriber a few weeks ago. Still learning the ropes) and select what I want to play. Then I click on the airplay symbol and a pull-down menu pops up. I select the ATV from my network and it plays on the AVR and my tv screen starts to show the song information and lyrics. I could very easily be mistaken about exactly what is happening here. Here are a few screenshots to illustrate what I think is happening.I do not understand how this is done. I appreciate if you elaborate further.
You are sending audio to AppleTV via AirPlay. You are not remote controlling the AppleTV. If you power down your iPad music will stop.I don’t really either. I start up my AVR and ATV. Then I use an IPad from the couch, open the Apple Music app (Just became an Apple Music suscriber a few weeks ago. Still learning the ropes) and select what I want to play. Then I click on the airplay symbol and a pull-down menu pops up. I select the ATV from my network and it plays on the AVR and my tv screen starts to show the song information and lyrics. I could very easily be mistaken about exactly what is happening here. Here are a few screenshots to illustrate what I think is happening.
Yeah that is accurate, you just use the phone as a remote, but Apple TV doesn’t support high res, and nor does airplayI can check my settings, but via Homekit, I can control an AppleTV and select the Apple Music app and play music through my Denon AVR.
I’m not casting or using Airplay, rather finding the AppleTV in Homekit and using my phone as a remote.
That being said, I don’t think I’m getting any better than 48/24
That is like using the AppleTV remote though isn't it? All iPhone's now have a remote accessed via the swipe down right menu (I don't know the name of that menu.)I can check my settings, but via Homekit, I can control an AppleTV and select the Apple Music app and play music through my Denon AVR.
That’s my take as well and is what I findThat is like using the AppleTV remote though isn't it? All iPhone's now have a remote accessed via the swipe down right menu (I don't know the name of that menu.)
However, if the TV is not on you will not able to operate the AppleTV as you don't see what you are controlling.
Am I correct?
Not quite true Apple TV4k . If you go to settings > apps > Music you can select lossless ALAC up to 24-bit/48 kHz.Yeah that is accurate, you just use the phone as a remote, but Apple TV doesn’t support high res, and nor does airplay
He was referring to Apple TV using the phone or iPad as a remote, not using airplay and he said he didn’t think he was getting better than 48khz/24bit, I agree and you just did too, what’s not true?Not quite true Apple TV4k . If you go to settings > apps > Music you can select lossless ALAC up to 24-bit/48 kHz.
If you use Airplay it gets reduced to 44/16
Is what you said. But it does, was my point.Apple TV doesn’t support high res
Some would say 24/48 is not hi-res as DVD had been 16/48 since 1996.Is what you said. But it does, was my point.
Buy a Bluetooth remoteStill no way to control Apple Music iOS devices from another iOS device ?
With apple classical music it is a bit painfull !
On my side, I have an old iPhone 8 connected to a usb to tosling converter then to two topping DACs by optical link.
It works perfectly well at 192/24 but I have to get up of my chair to change tracks...
