Hypex Ncore mute on startup - custom input board
Hi there. I am making a DIY build with some Hypex Ncore NC500MP boards. There will be a couple of amp modules in a box with custom input PCB for signal detect auto power on, 12V trigger IO, and temperature monitoring.
I was thinking of adding some kind of soft start functionality, i.e. have the amp modules muted on turn on/off, to reduce pops and/or speaker damage. At the moment, this is done by using the amp power good signal to control the amp mute input. Is there any point in doing this if I am controlling the amp ps enable line to bring amp modules in and out of standby mode. For reference, the amp module datasheet is here: https://www.hypex.nl/media/90/08/74/1646057938/NC500MP_04xx.pdf.
If anyone has any comments, suggestions, advice, that'd be much appreciated.
Rick Sykora
Stow, Ohio USA
Neurochrome.com already has a good soft start. If it does not work for you, he also offers some useful advice here:
p.s. Also Audiophonics has a range of options that are so inexpensive, may not make sense to design your own…
boXem
Europe
Having tried this solution, my advise: don't loose your time. The amp is muted until ready and then automatically un-muted. Keeping it muted and un-muting it later has no effect on startup noise. Exploring various ways of grounding can bring more satisfying results.
Count Arthur
Hypex make a soft-start module: https://www.diyclassd.com/products/diy-components/smps/softstart-module
However, as others have mentioned I don't think this is necessary with their current SMPS powered amp modules. Early on, when they first released their UcD modules they originally used them with a linear power supply, with toroidal transformers and a large bank of capacitors. For larger transformers, a soft-start was recommended to prevent the transformer and capacitor bank inrush current from blowing fuses or tripping RCDs.
Hypex UcD700HG with linear PSU and soft-start:
Rick Sykora
Stow, Ohio USA
I will add that I missed earlier that you plan to use Hypex MP modules, so the need for a soft start may be lessened. Otoh, the in-rush current on these is not insignificant and might be still worthwhile...
I would suggest dropping a quick note to Hypex support and see what they recommend.:)
M
Hi All. Thank you for all your replies. I think my question has been answered.
I won’t bother putting in extra muting driven by the amp power good signal. Similarly, I’ll let the amp SMPS power up without additional soft start circuitry.
