none..What brand class-D chip are they using? Does anyone know?
Looking at the specs this must be one of the best amplifiers ever made!
The "chip" is a Hypex NCx500 module (so Hypex brand, their NCOREx iteration)What brand class-D chip are they using? Does anyone know?
They are a fully discrete design. So no chips other than maybe a microcontroller for some monitoring duties.What brand class-D chip are they using? Does anyone know?
As far as I know they have their own. And yes, best Amp I ever gotWhat brand class-D chip are they using? Does anyone know?
Why to get an amp without noise and distortion and afterwards add noise and distortion by tubes?Gonna add an external tube buffer
It's exactly what I want, but I already have an amp without the internal buffer, and want to achieve that effect for $20
Would be interesting to see measurements and SINAD@Megaken you can buy a class D amp from VTV with an internal tube buffer, if that is what you want.
What an horrible idea ! Why do that to one of the best amps you can get
Plugins are the way to go..There is always Tube Saturator Vintage...
I always prefer my bile buffered.
I found Pro Tools Into that supports AAX plugins for freePlugins are the way to go..
I don't see why not and I use VAC in my Church setup to route signals to my stream and then back out to the live audience feed. As for ROON it should work the same as using VST plugins, but hopefully someone who is a regular room user or developer can chime inI found Pro Tools Into that supports AAX plugins for free
Does anyone of you know if I can connect a USB Audio interface to my Win PC and run the AAX plugin from digital in to digital out via this interface in realtime?
Edit:
Can virtual Audio cable be used with it and what about Roon integration?
