I eqed the sub-bass region on a 5" speaker without a sub (?) (LSR305)
Deluxillo
Perhaps it is stupid but in the absence of a subwoofer I have equalized the lack of sub-bass on these speakers and the result is more than decent. I've gained a lot more presence in that region and it makes me wonder if even a subwoofer is necessary. It doesn't sound distorted either. Am I doing something silly? Thank you.
escape2
USA
To do this, I'm guessing you must have cut a ton of gain from all the other regions. If, after this, the speaker is still getting loud enough for your needs, then I don't see a problem.
D
Deluxillo
Yes, I did it by hear. I will do a proper eq when I have a microphone. It surprises me because nobody talks about it. Even in REW you see the option to no touch that region if you dont have a bigger speaker or a subwoofer
Sancus
305p has no meaningful output below 40hz and EQ cannot fix that. You can apply some boost of course if you play very quietly, but if you are applying 20dB of boost you are limiting yourself to probably below 70dB playback without serious distortion problems. Too quiet for me but if you're happy with that it's fine.
D
Deluxillo
I'm very surprised too, but I hear a great 30hz bass extension with no problem. We will see in the future if an EQ with a microphone will be good enough not to buy a sub.
Reactions: 617
Chrispy
PNW
Define "great 30hz" extension....how did you measure?
Chrispy
PNW
By hear and comparing it with a good eqed headphone. As I said I dont have a microphone to test anything.
Only so meaningful then. I have a pair and would just use a sub.
D
Deluxillo
I did this EQ, Var smoothing. Sounds Great!!
But indeed, the volume is too low. If a buy an amp, and produce more volume, will I damage the speakers or get some distorsions?
Seems like a great subtitute to a subwoofer for <30hz
RayDunzl
Central Scrutinizer
Riverview FL
Mine (MkII version) seem to go a little lower.
With and without EQ, 1/6 smoothing
phoenixdogfan
Nashville
If you compared your eq'd 305s with a set with a sub you would immediately realize you have not done what you think you have. But it you like it, enjoy.
RayDunzl
Central Scrutinizer
Riverview FL
I subtracted annoying boom in the room, and smoothed out the rest of the range a little, with no intention to increase to the low, as an experiment four years ago.
They would seem to me to have "meaningful" bass down to 31Hz, which is enough for the intended purpose, to play HDRadio in the garage.
dasdoing
Salvador-Bahia-Brasil
you forgot about room gain.
Not at all. as others have said, you will have problems when playing loudly. also distorsion will be high in the boosted region. but it sure is better than having nothing there. did this for many years before buying a sub
D
Deluxillo
Im not hearing distorsion using tonegenerator with very loud volume in the boosted hzs. If I buy an amp should everything be okay?
dasdoing
well, here: https://jblpro.com/products/lsr305
they say
Max Peak Input+23 dBu
which should be above your DAC, so you could aply come extra gain,
BUT I never heard of anybody using an amp for a powered speaker,
and you still will be limited by how much SPL the speaker can produce down there before it distorts or the port starts to make noises.
is it safe to try? I don't think so lol
D
Deluxillo
you risk over excursion of the woofer > damage
you risk clipping the AMP > damage
Hmmm… it seems like best is to get a subwoofer then. Is there any sub recommended for a medium room house with these speakers? I find the LSR310 very expensive
