I need your help in choosing a DAC.
Avul
Hello, friends! I need your help in choosing a DAC. I assembled a new computer. And I do not want to put a sound card. Previously installed was the Xonar Essence ST the ASUS.
What I have. This amplifier is Yamaha as500, Dynamics Magnat Quantum 673.
My budget is 200 - 300 $.
I'm considering two options - topping d50 or topping d30 + a30.
What will be your opinion, recommendations.
And I am sorry for my english. )))
andreasmaaan
No problem about your English :)
Will you use it with headphones?
A
Avul
Yes, I currently have Audio-Technica ATH-MSR7
andreasmaaan
Ok, the A30 has a high output impedance of around 10 Ohm. Your headphones have an input impedance of about 36 Ohm. So in theory, they should not be a good match. However, because the headphones have a smooth impedance response and are sensitive, it shouldn't be a problem. Someone else might have a better suggestion than the A30 though.
The Topping D10 measures just as well or better than the D30 and is cheaper, so it might be a better choice. Both should sound exactly the same (transparent).
A
Avul
Thanks for the reply.
