IEC 60318-4 Clone Coupler, is it worth it?
IVX
South of China, SHZ area, - Слава Україні
Earfonia, I did a record of the coupler + rig with artificial ear-pina(from the same shop). First, I compensated my HFM HE400i to fit Harman_AE curve +/-1db 20-10000Hz(oct/6 smoothing), second, I recorded the CD track from the coupler, and finally unEQ the record with (Harman_AE)^-1. It sounds Ok close to the original track to me but isn't perfect.
lemon07r
Earfonia
Earfonia
Singapore
Sorry for late reply I was quite busy for the last few months .
To my ears the comparison sounds pretty good! Did you remove the nozzle and connect to the artificial ear-pina?
I haven't tried mine for headphone yet, because the artificial ear-pina looks a bit expensive and I'm not sure of the quality and how close the shape to the standard.
Earfonia
Earfonia
Singapore
Does anyone have a cheap iec 60318-4 spec coupler recc off Ali to play around with? https://m.aliexpress.com/item/1005001844592992.html?spm=a2g0n.shopcart-amp.item.1005001844592992& I was thinking of getting this one, it's pretty cheap but I'm wondering if it's missing anything like the microphone cause I see a lot of other sellers selling the same one for more than twice the cost and I can't tell if it's missing anything from the product description page or review.
From the shape and size it doesn't seem to conform with the IEC 60318-4. Diameter seems smaller than IEC 60318-4 coupler.
This one looks better from the shape and size, closer to IEC 60318-4 standard:
lemon07r
Thanks, would you say this is about the same as well? https://m.aliexpress.com/item/40009...er_id=de0811157ec74ef09dc95ee766ce6646&is_c=N
Earfonia
Earfonia
Singapore
lemon07r
Did you buy this coupler? Have you tried? I'm curious, looking to get cheap 711 coupler for my brother.
I got it but havent gotten around to setting it up yet cause my current setup is no good (I have no balanced adc to calibrate my 9038s g3 with), though since I only have the 5v 3.5mm mic version I may just use it with my motherboard audio 3.5mm input/output.. Only issue is my motherboard audio picks up a ton of noise for some reason, and this happens even if i use a topping d10 dac. If there's even a tiny bit gpu/cpu usage or mouse movement my speakers playback noise lol. Im building a new pc so ive postponed using my coupler until then, hopefully the integrated audio in that pc will suffice.
I kinda regret not going for the base version that comes with the icp prepolarized mic. That plus a 9038s g3 for balanced output, and cosmos adc for balanced input would have made a killer bang for your buck combo now that I think about it. Especially if you can get it calibrated outside of vendor calibration like you did with your setup. Maybe one day when Im more well off haha.
Earfonia
Earfonia
Singapore
Noted.
Happened to me before those noise issues with audio DACs. Up to the point that my mouse scroll wheel causing audible clicking noises on my earphones. Solved with USB isolator, those USB isolators that use Analog Devices ADUM chips. I guess it was USB ground loop issue. But those USB isolators usually only comes with 12 Mbps speed, so no DSD playback. Not sure if the newer ones these days have better speed. I encounter that issue like more than 10 years ago.
lemon07r
Noted.
I looked into it a bit since my last post. That is the quick fix, a usb isolator, but the cheap ones will limit your dac/adc a bit like you said. There are newer and better ones like the iFi Audio iDefender3.0 but those are expensive, I might as well buy a new ADC/DAC for the price. At least I've figured out how to fix the noise now, I basically need a usb dac/adc that uses a separate auxiliary power source, or a usb noise isolator like you said.
The D10 DAC I had takes power directly from the usb input so that explains why it carried on the noise. At least now I know I can work around it with just getting a dac that can take power from a different source. Of course I could buy another D10 or D10s (since I sold my last) but then I would also need to purchase something like the idefender3.0.. (since a cheap isolator would defeat the point of spending extra for a good dac) which would be more expensive than just getting a topping e30 or smsl sanskrit 10th mkii which can take power from a separate source.
Well, that's kind of off topic. Now for the issue at hand.. from what I can tell I have the following options:
1. Get a balanced ADC to go with my 9038s g3
2. Get a cheap balanced usb interface and usb isolator and just use that
3. Get a decent 3.5mm balanced dac so I can use the motherboard's 3.5mm input.
Option 1 seems to be the most expensive, even if it would give me the best results. I can't find a cheap audio interface or adc with balanced input for my life. I might as well get the cosmos adc, and an xlr to bnc cable if I go that route.
Option 2 is the cheapish option, something like a Audio-Technica Consumer ATR2x plus cheap usb isolator should do the trick but I would be at the mercy of my cheap gear's questionable quality I think.
Option 3, would actually be the cheapest, since I could just get an apple usb-c to 3.5mm dongle, and it would be decent enough. I'm just worried if it would pickup noise from my pc, or if my motherboard 3.5mm input will be any decent.
Earfonia
Earfonia
Singapore
For the IEM measurement option 3 seems to be fine.
For other USB noise issue this Topping HS01 could be a quick fix. Not cheap but not terribly expensive like the Intona USB Isolators:
lemon07r
Looks the same as the ifi one! I bet it is the same thing just different brand and pricing. Let me see, would cost me around 200 bucks to get that with another D10 or the newer D10s, I should probably just buy smsl sanskrit 10th mkii for 130 bucks or so instead, since that can take auxiliary power by default, and is also a better dac. Or.. I just realized something, I can kill two birds with one stone. The loxjie D30 for 200 or so bucks is better than the d10s and doubles as a headphone dac since it has 3.5mm output.. so I can use it for my measurements too. Why didnt I think of this sooner.. I'll report back on how the coupler is once I get it set up.
sukoon
My journey in In-Ear Monitor (IEM) measurement started with some common measurement microphones and DIY shrink tube couplers.
I've been interested in IEM measurement for quite a long time, but not ready to spend big bucks on GRAS or B&K couplers. The idea is to search for a more affordable measurement setup that can produce meaningful result. What I mean by meaningful is that the measurement result is at least consistent, so we can compare different IEMs measurements and get consistent result from the setup. Besides that I hope the measurement result is, to a certain degree, more or less comparable to the measurement result from those expensive couplers.
For the last 2 years or more I've been using China clone IEC 60318-4 couplers and I would like to share what I've learned here.
Big thanks to @JohnYang1997 for some info he shared with me that helped me in making the right decision in purchasing my latest IEC coupler from Taobao that has been my main IEC coupler for now.
Now I have 3 clone (read: compliant) IEC 60318-4 couplers:
  1. IEC 60318-4 plinth coupler with ½ inch ICP prepolarized microphone. Model E610A SN: 20229 (latest purchase)
  2. IEC 60318-4 plinth coupler with plug-in-powered (±5V) microphone. Model E610A SN: 20201
  3. IEC 60318-4 coupler without microphone, model E610A coupler SN: 30168
View attachment 133095 View attachment 133099 View attachment 133098
The coupler without mic can be attached to measurement mic with nozzle diameter around 12.7 mm. For example MiniDSP UMIK-1.
The 1st and 2nd couplers in the list come with a build in microphone and calibration files.
A few lessons that I've learned from using the clone couplers:
1. The calibration files were poorly done, and therefore useless. So we need a way to calibrate the clone couplers with better coupler like the GRAS or B&K couplers. This is quite a challenge if we don't have access to exactly the same IEM measured by GRAS or B&K couplers and compare the measurement with their measurement result. Fortunately the 1st coupler in the list above produce pretty close measurement result with GRAS RA0045-S1, even without any calibration file.
2. When calibrated, some clone couplers can produce measurement result pretty close to the better and more expensive couplers like the GRAS coupler.
3. Although frequency response can be calibrated, harmonic distortion measurement cannot be calibrated. So poor microphone usually resulting in higher THD measurement than THD measurement result from a good branded coupler.
Thanks to a Head-Fi member, csglinux from https://www.hypethesonics.com/, he started a tour of Etymotic ER2SE measurement, so that I (and other participating members) could compare measurements of ER2SE and few other IEMs in the tour package with his GRAS RA0045-S1 coupler (RA0045 coupler + 40AO mic + 26CA preamp).
https://www.head-fi.org/threads/ety...phone-for-your-ears-and-your-couplers.908512/
After about 2 weeks of non-stop measurements and drafting the calibration files for my latest coupler (SN: 20229), the following are the comparisons of frequency response measurement result from GRAS RA0045-S1 and my coupler, E610A-SN20229. All measurements were done at 94 dB SPL at 500 Hz, but I shifted the right channel measurement down 5 dB after measurement in REW, just to visually separate them from the left channel for easier observation.
Left on Top, Right at the Bottom. GRAS RA0045 in Red, my clone coupler E610A-SN20229 in Blue.
Etymotic ER2SE:
Samsung earphones EO-IG955 (Tuned by AKG)
Sony MH755:
BLON BL-05:
The reason I was looking for a better coupler and finally bought the ICP mic based coupler, is to get better THD measurement. The THD measurement from the coupler with plug-in-powered microphone (SN: 20201) is always higher than expected. Among the 4 IEMs in the tour kit, BLON BL-05 is the most impressive in THD measurement. It has very low THD to test the capability of the coupler. The coupler with plug-in-powered microphone showing THD measurement in the range of 0.5% - 1.0% THD for BLON BL-05, while the ICP mic based coupler (SN: 20229) goes down to lower than 0.01%, showing similar curve to the GRAS RA0045 with only slightly higher overall THD. Pretty impressive for a coupler that cost probably 1/6 - 1/7 of the GRAS RA0045-S1.
BLON BL-05 - Left THD - GRAS RA0045-S1:
BLON BL-05 - Left THD - E610A-20229 (Clone Coupler):
Here is my current measurement setup:
Both RME Babyface Pro FS and the B&K 1704 are battery powered, because I put everything inside a Pelican case that function as noise isolation container. It is very difficult to measure IEM with low THD like the BLON BL-05 without noise isolation container, because the ambient noise will be higher than the harmonic distortion signal that will be measured. I cut a hole on the Pelican case to install USB 3.0 coupler for USB connection of the Babyface Pro FS to my computer. I added 1 inch high density rubber mat and sound isolation seal to improve the noise isolation.
My conclusion so far, I'm quite happy with my latest clone coupler (ICP Mic - SN: 20229). IMHO it is worth it.
One day I might end up with a GRAS coupler, but for now, this clone coupler is good enough.
I recently ordered the Panasonic RP-TCM125 IEM for measurement, so I can compare it with Amir's review of that IEM:
https://www.audiosciencereview.com/.../panasonic-rp-tcm125-review-budget-iem.22797/
If @amirm has the time, I would love to send over a few IEMs to be compared to Amir's GRAS 45CA :)
Anyone who has experience with IEC 60318-4 clone couplers, please share your experience so we can learn which clone coupler is worth the money and which are not :)
Where did you get those/how did you make those shrink tubes
