IEM cable without stiffened ear hooks?
Jimbob54
Can anyone suggest an aftermarket IEM cable make/ model that doesnt have the reinforced "bend" after the earpiece connection?
I want to wear some IEM upside down (dont ask) but the ear hooks of course dont help when one wants the cables to point downwards.
Ideally 2.5mm and MMCX but Im sure most makes will have termination options. Im in the UK.
Thanks in advance.
majingotan
Laguna, Philippines
Thanks in advance.
You can buy a replacement Etymotic IEM cable since they don't come with ear hooks.
Human Bass
Most sellers on Ali Express remove the stiffing plastic if you ask them.
Jimbob54
Jimbob54
Thats very useful to know! I'll see how the £20 Yinyoo from Amazon UK are first when they arrive.
Matias
São Paulo, Brazil
I own 2 cables from Yinyoo and they are fine.
RJO
Can you not carefully remove the plastic sleeve yourself? I checked my FD7 and it looks doable.
Jimbob54
Jimbob54
That would always end badly with me.
Jimbob54
Jimbob54
Oh o
Oh ok, just wanted you to save money because they're stock cable is already pretty good.
I'll suffer the £20 for a replacement and saving the misery of me ruining a perfectly good one as well. I considered removing the stiffener but I would almost certainly knick the main cable
Reactions: RJO
Jimbob54
Jimbob54
But thanks for the tip
You're braver than me!
Jimbob54
Jimbob54
I got this one - reasonable price, decent cable, decent connectors. Works a treat.
