iFi iPower SMPS’s better than standart SMPS?
eyes-on-you
Istanbul
Hi everyone,
I bought 3 of them when my old ‘golden ear’ times to use with router before reading here.
Last night, i noticed some improvement on upper frequencies when i disconnect them to swap to stock smps of router.
Also lower frequencies relaxed with stock one as my subjective impressions.
I come and check the ASR forum, there is some performance drop with the ifi power supplies here but another forums, they share good measurements with ifi.
I am very confused about ifi i power so i need your advice; replace them or not.
Jimbob54
Hi everyone,
I'd be intrigued to know how the power supply to your router has any impact on what comes out of your speakers, regardless of how good or bad that power supply is.
eyes-on-you
eyes-on-you
Istanbul
Hello there,
I would like to share the measurements if I have the opportunity, but I have no other than subjective comments.
Maybe it has something to do with the leakage current, I don't know.
I wouldn't ask here if I already had an answer
Ariamella
It won't have any more of an effect than a typical phone charger will, that's for sure
