Impedance matching
Ned
I am interfacing PCM5100A audio DAC which is 2.1 Vrms (Ground Center), Stereo line output load (1K ohm, nominal 10K ohm) to a mixer stage audio channel that is 500 ohm input.
I am using only a single output (mono) channel from the DAC and the DAC output is connected, per its application note, to a 470 ohm resistor and 2.2nF cap (RC).
Having only basic knowledge with impedance matching; Does the 470 ohm resistor in series with the DAC output increase the input impedance to near 1k? Hence, testing this in practice is working without attenuation.
Or should I consider adding a simple op-amp; not to amplify the signal, but to lower the output impedance? Any advice on the op-amp and its schematics is highly appreciated.
Thanks
Ned
DVDdoug
We don't impedance match with modern audio... It was a thing back in the days of audio transformers & tubes...
You want a low impedance source driving a higher impedance load.
The microphone inputs might be 500 Ohms but line inputs should be 10K or more. Microphone signals are also millivolts so a mic input is "wrong" for your DAC output.
Just for a different example, an amplifier with an 8-Ohm output is rated for use with 8-Ohm (or higher) speakers but it has an internal source impedance of less than 1 Ohm. The ratio of load impedance to output impedance is the "damping factor". Sometimes you'll see a spec for that and higher is better (up to the point to where it's high enough that it doesn't matter).
N
Ned
Thanks for the reply.
To achieve this then do I need to lower the 1K min load line output of the DAC to at least 500 ohm or lower?
The mixer input is Line input marked only as 500 ohms input impedance.
DonR
Vancouver(ish)
Ideally, you want a unity-gain op-amp buffer after the DAC and before the mixer. Infinite (or close enough) input impedance with a sub-50 ohm (usually under 1) output impedance.
sarumbear
Are you sure that your mixer’s line input has such a low input impedance?
N
Ned
A voltage follower and a mechanism to limit the current.
Yes, its a custom 8 channel line inputs that clearly marked for 500 ohm input and then it outputs the mixed signals to a 500 ohm impedance headphones.
DonR
Vancouver(ish)
Yes, even a 50-ohm resistor on the output would be enough to limit the current in the event of a short circuit and you would still have only a 50-ohm output impedance.
