Integrated Amp Purchasing Strategy
feelingtheplot
I've got ~$500 to spend on an integrated amp and am just getting into audio as a hobby. Would it be better to spend ~$500 now on the best vintage/used integrated amp I can find, with the knowledge that I would basically use it just as a pre-amp (buying a crossover to add a sub, a nicer power amp, etc down the line) or starting with a separate $250 preamp (looking at used Kenwood C2) and $250 power amp?
If I should start with an integrated amp, which vintage or used brands/models are known for their phono stage? Also very open to buying new, it just seems like the value is in used.
BeeKay
EU
Vintage stuff - I maybe would be careful I wasn’t able to service such gear myself (I am not). There is certainly good and refurbished gear available. But this comes at a price. So if you are not into the looks or the sound signature of such older devices, the money could be better spent on modern gear.
Doodski
Buy new gear. Get a miniDSP and build from there.
DMill
Vintage gear is always a risk unless you know how to repair it. I’d buy new and enjoy a return policy. Plenty of nice integrated offerings at $500.
JSmith
Algol Perseus
integrated amp
This may be of interest;
Open box, $200 off; https://www.ebay.com/itm/285091403098
JSmith
mhardy6647
Yamaha would be well worth a look. Consider one of the lower-end Yamaha integrated amplifiers (A-S301 or A-S501) if it meets your requirements, @feelingtheplot
Despite a certain... affinity... for vintage hifi hardware :rolleyes: I cannot recommend it as a starting point at this late date. To buy a rehabilitated piece won't be cost effective, and buying as-is is always a crapshoot -- and as @tonycollinet mentions, we're not in what one would consider a buyers' market for vintage anything.
Finally, I apologize prospectively for subjecting y'all to this (yet again), but when the words Yamaha and vintage pop up, I simply can't resist...
TonyJZX
is it a hard ask these days for a usd $500 integrated that has a good phono stage AND has decent power and comes up to asr standards?
does digital matter to you in both regards... are you amenable to Class D and do you require a dac inside?
i quite like integrateds even though I quite like separates.... if i'm after a 19" rack sized unit there's a few non negotiables for me at this price
pre-outs
i'm ok with line stage... if you're a vinyl guy you probably invest in phono preamps
i'm ok with no dac... dacs being so cheap I'd rather not be tied down to whatever is in the unit
i'm ok with no loops... i dont have a recording deck
i'm sort of ok with no HT preamp bypass
ok being single ended
I am definitely ok with no streaming no bluetooth no ethernet
remote and real tactile volume knob please
i'm ok with sacrificing some of this if the form factor halves etc. if you lose preouts but its a tiny half width unit with sufficent power then thats ok
eg. any of the new breed china digital units
antcollinet
UK/Cheshire
And it makes me envious every time. Really sad that the Sony Amp, Tuner, and tape deck dissappeared when my parents moved to USA in 1980.
F
feelingtheplot
@mhardy6647 I, perhaps unwisely, just picked a beautiful CA-800 unit that had a complete restoration. Talking full recap, board disassembly and cleaning, resoldering, new circuit switches, etc. Was too good to pass up, decided to treat myself and stretch the budget
mhardy6647
Good luck! :cool:
The CA-800 is probably my favorite, FWIW.
Not to say it's the sine qua non -- but of my somewhat motley lot, it's the one that I like to listen to the most.
restorer-john
The class A/AB switching should have been restored. Ask the seller what was done in that respect. Two sets of switches hang off that lever, one for the biasing, the other for the rail switching.
ahofer
New York City
Good luck! :cool:
Adjustable loudness FTW!
