Balle Clorin
- Joined
- Dec 26, 2017
- Messages
- 1,349
- Likes
- 1,220
Just to avoid misunderstandings, Puffin Digital out does not require any modification , I bought mine including Toslink out.
I truly appreciate this sentiment. To be honest I am worried it will sound horrendous, given how resolving 8351s are…
Are you sure the digital out would output what the turntable is playing? I have the impression that it only routes from USB to SPDIF or OPTICAL and not from the phono line-in.For a phono stage with digital out another option would be the ART Phono Plus. IIRC/FWIW there was a special art package for Tool's Fear Inoculum for a limited number of CDs?
Yes it's primarily for digitising vinyl....which is why I got one.Are you sure the digital out would output what the turntable is playing? I have the impression that it only routes from USB to SPDIF or OPTICAL and not from the phono line-in.
It won't sound horrendous. But it will sound subtly (or not so subtly) different to any digital version of same release. In some cases it may even sound more pleasing depending on what floats your proverbial. But after some time you will begin to question your life choices: having to get up off the sofa every 20 minutes, those always apparent pops and clicks, having to walk on tiptoes all the time in case the needle jumps, the knowledge that any digital version will always be more accurate to the source, the nagging doubt that however cool it may seem it really doesn't sound better ...To be honest I am worried it will sound horrendous
No problem with that. Enjoy! Doesn't mean you have to listen to the damn things. People collect stamps or beer labels and they don't even have the possibility of making a noise ... ;-)I've actually been thinking for a while now to start collecting vinyls just for the artwork
Nice one, Phono Plus looks great. And yes, all editions of Fear Inoculum are gorgeous. CD comes with a LCD screen that plays a small ambient video. Both CD and vinyl have similar booklets and the quality of design is through the roof. Actually all TOOL albums come with unique and beautiful packaging.For a phono stage with digital out another option would be the ART Phono Plus. IIRC/FWIW there was a special art package for Tool's Fear Inoculum for a limited number of CDs?
Yeah, forgot about the ambient video....been a while....I just got the normal cd. I never heard Tool on vinyl in the first place myself....Nice one, Phono Plus looks great. And yes, all editions of Fear Inoculum are gorgeous. CD comes with a LCD screen that plays a small ambient video. Both CD and vinyl have similar booklets and the quality of design is through the roof. Actually all TOOL albums come with unique and beautiful packaging.
The problem is that a phono cart need 47 Kohms ohm input impedance which is usually only found on phono pre-amps. In the case of the Flex it is either 100 Kohms or 200 Kohms depending if it is balanced or unbalanced.Have you jumped yet?
One, sideways, option - sell your miniDSP and replace with a miniDSP Flex (balanced) which has an analogue input ...
I've heard that you can carry out the RIAA correction directly in the miniDSP Flex - i.e. no need for a phono stage. Don't know how though but it's intriguing.
Enjoy
Thanks for clarifying ... so OP will still need a phono stage. There are plenty.The problem is that a phono cart need 47 Kohms ohm input impedance which is usually only found on phono pre-amps. In the case of the Flex it is either 100 Kohms or 200 Kohms depending if it is balanced or unbalanced.
I run my phono pre into a miniDSP Flex. Well, not directly. The only caveat to this setup is you need to attenuate the signal between the phono pre and the Flex because the Flex clips at only 2V input on the unbalanced version. I run my Flex with Dirac Live between the preamp and power amp for this reason, but if I was using the Flex as a preamp I'd definitely stick a decent-quality passive attenuator in between, like a Schiit Sys or JDS Labs OL Switcher, with the pot set to 12 o'clock. If the overall gain ends up being too low it can be bumped up without adding noticeable noise floor in the Flex.Thanks for clarifying ... so OP will still need a phono stage. There are plenty.
