Hello everyone,
I am trying to integrate an 80s Technics SU - Z22 amplifier and a pair of 1977 Bose 301 series I with a PC (Windows 10).
I realize its not the best gear to spend time and money on, but they were my fathers, and its a sentimental thing.
I would like to be able to use them as a general wireless audio out for the PC, for music as well as movies etc.
Ive been looking at what options I have, and everything points to either a Bluetooth or a WiFi DAC.
I am looking to spend up to around 100€, but would go to 200-300€ if it would make sense price/performance wise.
Aaand since I have no idea about this kind of tech, I have some questions
1) Would it be better to use WiFi instead of Bluetooth for the higher bandwidth, or would I not be able to notice the difference in sound quality anyway, and is Bluetooth enough? Or is there some other, better option I missed?
2) I understand that I need a DAC on the amp side to receive the Bluetooth/WiFi signal and send it to the amp via an audio cable, but do I also need some sort of specialized USB dongle or something to connect through from my PC to the DAC, and have the PC actually recognise the DAC as an audio out? Or would the signal just be transmitted via a regular WiFi/Bluetooth connection?
3) What gear would you recommend, that would make sense with this setup? I dont want to needlessly buy the best and most expensive stuff, that the speakers & amp wont be able to take advantage of anyway, but I also dont want to loose a noticeable amount of sound quality because of the DAC.
4) The speakers have been serviced 10 years ago - at least the cone and diaphragm replaced I think, if not the whole drivers, and they have hardly been used since then. Im guessing they will hold up for a while longer?
Cheers!
Cheers!
