It will be punchy until port distortion hits the fan. If you do just 4dBof baffle step compensation, you'll get at 96dB (Amirs standard for distortion measurements) with 10V signal (28W). There is +3dB hump at 58Hz and the port distortion goes nuts.
View attachment 116175View attachment 116174
This just isn't a midwoofer for small ported cabinet. With PR, maybe. But ported needs larger volume so floorstander is mandatory if you want to really use that high Xmax and low distortion motor.
As always, I respect your opinion Zvu,
But here I will respectfully disagree.
When I model the Purifi PTT6.5 and then compare it, to say, the Scan-Speak 15W/8530, I find that both model very similarly (same Vas, Fs, and Qts)
The port size requirements and air speed and group delay are also similar etc.
Paul Carmody uses the 15W/8530 in the Carrerra- a 15L cabinet tuned at 38 or 43Hz. and there is nothing wrong with the port tuning or bass there. In fact, it’s delicious, for 1/2 cu ft speaker.
I think the way to look at the Purifi is the same.
‘Great sound in a smaller box’.
Erin from Erins Audio Corner has already shown that it in free air, it can reach 100dB cleanly with 12V input.
In a 2 way design I think trying to eek out every mm of x-max and push it to its suspension limits is not necessary. So I’m not modelling it with 100W of input or trying to use up all 10mm of its x-max.
Furthermore, whether one can hear port turbulences and resonances when the port is rear firing, well I’d like to see some studies on it, but if it’s anything like a woofer’s limits under CEA 2010, then probably it’s hard to discern.
And let’s not forget masking effects. When I have 2 speakers, each playing at 96dB, i have a lot more things to worry about, like other things being driven to buzz or shaking in my room.
So I’m not surprised at Rick’s preliminary audition of these- that the port visual measurements looks worse than it actually sounds.
In my own design of a PTT6.5 in a larger box, documented at DIYAudio, I also don’t have any problems with a vented design in a 3/4 cu ft box.
