Iphone as a source
TankTop
Not sure where to put this, please move if it’s in the inappropriate for him.
First, will an iPhone (Xs) lightning to USB B work for audio output to something like a Topping DX7 pro or similar. If so what is the Signal quality the iPhone is capable of.
I ordered the Sennheiser HD6xx and I’m just thinking of an equipment purchasing plan. would want a headphone amp/sac that could also be used as a pre amp for powered bookshelf speakers. If the iPhone could be used as a quality source that would be a savings.
T
TankTop
iPhone headphone adapter...
https://www.audiosciencereview.com/...pple-iphone-lightning-headphone-adapter.7665/
Teamed with JDS Labs Atom *or* Schiit Magni 3 Heresy *or* Gersahelli Labs Archel 2.
Sit back and enjoy.
The Atom will definitely work as a pre-amp in the way you envisage (that's how I use it). Not sure about the other choices.
Thanks, I was specifically thinking of the Atom. So just lightning to headphone jack, no need to make it more complicated.
Berwhale
No, not really. You can always add a desktop DAC later on if you feel the need. I know that only certain DACs are advertised as iPhone compatible (e.g. Chord Mojo), i'm not an iPhone user, so I don't know if compatibility is an issue for other DACs.
Wes
SQ from an iPhone is not a limitation
use Apple lossless instead of mp3 for best SQ
Space is the limitation
T
TankTop
What’s the quality of streaming Tidal or Tidal Masters from the iPhone? From the sound of your comment it’s good enough. Tidal via Bluetooth in my car is a huge improvement over radio or pandora.
Berwhale
Tidal Hi-Fi should be equivalent to CD quality FLAC, Tidal Masters could be better or worse depending on your view of MQA and it's effect on sound quality.
