Is 14 AWG good enough for speaker cable?
ripwire
This one has me a little confused. I'm going to DIY some speaker cables, figure it's going to be under 6 feet (2m). I've been browsing through the forum to see what size I need/is recommended, but I don't seem to be getting anywhere.
One post did mention 16 AWG is good enough. Then there's Amirm's review of various 12 AWG cables.
Why am I looking at 14 AWG? Well, I'm also having to look around for connectors. Since it's a banana jack, my first instinct is to look at one of these Stäubli L-41/A plugs. They're used in electrical engineering test & measurement, are from a reputable company, are rated for 32A and are gold plated to boot. The only issue is they're speced for 2.5 mm² wire at most. 14 AWG will fit, 12 AWG won't.
Admittedly they might not be the best choice, and if I want/need thicker cable I'm going to have to search for other options.
Also, no, I'm not looking for anything fancy, just good plain copper wire. Preferably in a black jacket. I'm probably going to go for Belden's 5200UP/5100UP/5000UP, or if I really want to splurge, Mogami's W3103. The latter assuming I can find a suitable plug for it.
Colonel7
Maryland, USA
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Waxx
Wodecq, Hainaut, Belgium
I use 1.5mm² (almost 14gauge, that is 1.63mm²) wire for most of my speaker cables since like forever. Maybe for high power applications it may not be enough, but for hifi (even relative high power hifi) it's more than enough if the cable is not too long.
DonH56
Monument, CO
wgscott
Yes. If it is good enough for 15 amps 120 V, it is good enough for speakers. I use 12 AWG, but only because that was what the botique vendor (Blue Jeans Cable) had. The thicker the wire, the harder it is to work with.
fpitas
Northern Virginia, USA
Size matters.
/What?
Ricardus
Northern GA
YES
Parts Express had a killer sale on 12 gauge about 2 years ago so I bought 100 ft. I can't remember the price but it was ridiculously low. They were out of the 14 so I went with the 12. But 14 is going to be fine unless you're pushing massive amounts of wattage... like live sound subwoofer kinds of wattage.
fpitas
YES
That, or low ohm speakers, or a very long run. If you have an amp with massive DF, you may want huge wire to not destroy the DF, too.
egellings
Dissipation factors larger than 20 or so do not bring any improvement in sound, unless the speaker has a vicious input impedance. Most don't. It certainly does not hurt to have high DF, but I would not pay more just to get just that kind of improvement in an amplifier.
fpitas
It depends, really. I'm happy enough with about 200 for a cone driver. But some people own an amp with large damping factor. If they use skinny wire with it, that becomes moot.
A pet peeve is those with passive speakers that go for extreme DF amps. The bad news is, the inductors in the crossover have several tenths of an ohm, or more.
egellings
200 is vastly more than you need, but again, it certainly doesn't hurt anything. High DF automatically comes with S.S. amps that use a lot of negative feedback to lower forward gain and consequently, DF, which is just a nominal number (8, usually, for 8-ohm speakers) divided the output impedance of the amplifier. You are correct in saying that a thin speaker wire will effectively raise the DF, since the wire's impedance just adds to the amplifier's.
fpitas
peng
Speedskater
Cleveland, Ohio USA
Well it all depends on the length of the cable and the loudspeakers impedance curve.
In most situations 14AWG is more than adequate.
But for the installing audiophile's peace of mind, going to a larger wire doesn't cost that much.
fpitas
Yeah, that's my position too. The extra cost of bigger wire just isn't a big deal.
MattHooper
I have 45 - 50 foot runs from my amps to my speakers (stereo system and home theater speakers). I chose 10AWG Belden speaker cable so as to ensure as little loss as possible. Likely overkill even for my situation, but it lends some peace of mind.
egellings
I agree that having peace of mind about how a system is configured makes the music go down like good medicine, even if a change is not necessary or does nothing audible.
kemmler3D
San Francisco
I'm going to give you some interesting advice: If you want to gain street cred on the objectivist audio forums (like this one) use the absolute cheapest cable you can find. These threads always attract comments like "I found 1200 feet of old 20ga lamp cord in an abandoned factory under a pile of broken glass, so I terminated it with bits of my kid's erector set, sounds great". If you show off how cavalier you are about speaker cable, you will earn a lot of brownie points around here. ;)
The real answer is for normal lengths, normal amps, and normal speakers, pretty much any copper wire thicker than a paperclip will deliver good performance. This is disappointing to many people as better wire seems like a really simple way to upgrade their system, unfortunately it doesn't work like that.
fpitas
Large gauge extension cords on sale is a great source of wire.
